Sr package,
over 200atw, remap, t28bb, braided lines, solid intake
tight 5speed, with carbon drift clutch
$3500 ( can see running )
Hybrid Fmic Kit
$400
Teins with cusco tops
$700 ride hard as, no noises
Cusco rear strut brace
$120
Whiteline Fr Brace[/b
$100
Clear tailights, ( neva seen same ones in S.a )
$250
Rolling shell, with new paint, front bar bit f**ked $1500
Profec B
$250
17x7 rims with small dish 5 of
$500
pics of car should be a page back
any more pics or info txt on 0407 627 431
hey guys,
help me get to track day!
R32 GTS GTR carbon Nismo Trunk Spoiler - 200
R32 GTS GTR carbon air Deflector - $165
0433 290 801
Pics of spoiler please, txt them to me.
For sale
R32 jasma catback 3.5" with cannon 150$
R32 front reo not cut 100$
Front drivers seat mint 100$
Pair of 34 stockies 17x7.5 shresdes Tyres 100$
Set of territories 17x8 good offset 350$
Stripping r32 so just ask.
Open to offers
Contact 0435163144
FOR SALE
Haines Hunter 1800S Ski Boat
Powered by Evinrude 175 VRO power tilt and trim
Includes intermediate prop on moter,Raker Prop and spare standard prop
New plugs and stainless steel leads
New VRO Unit and Igniter coil
New heavy duty calcium battery
On fully galvanised trailer fitted with self guiding rollers
New light truck tyres and spare
5 Safety vests
2 Fire extinguishers
Radio and speakers
Fitted with 60lt stainless steel bow tank and 70lt stainless steel centre tank
Sky pole and rigging (6ft Ski pole)
Full storm cover
Very quick boat (can do 110kph on glassy water)
Allways kept under cover and very well looked after,regretful sale but no longer used and its taking up space.
Pics available on request via email.
Phone Cliff 0413 059 611
Email [email protected]
$11500 ono
Edited by funki_munki
R33 set of stock struts with aftermarket rs*r springs great for street $200
R33 rear seats $200
R33 centre console $50
Titanium 3 inch rear muffler sounds and looks unreal $200
Stock rb25 dump/ front pipe $50
R33 a/c parts inc. Motor, pulley, engine block bracket, condensor, lines ect $100 for the lot
Stock r33 front camber arms $50
R33 wiper bottle $30
9mm neck pod filter $5
R33 centre roof light $30
Hks mushroom style pod filter brand new still in box $50
0417084638
r33 front braided brake lines $60
r33 series 1 grill $50
r33 rb25 series 2 engine loom $60
r33 coupe driver side window switch surround in CF wrap $15
r33 series 2 coupe driver side window switch $30
today only otherwise its going in the skip.
This car was going to be built as a daily driver but the owner has new plans now. car is ALMOST finished. just needs an exahsut and interior put back together. apart from that everything else is done! Car is currently unreg and will be sold as such but has papers and legit plates to re rego it. Has never been defected!
Specs:
  • KE70 flat front
  • ORIGINAL 98,000 kms on the car. Chassis is 100% rust free, interior while currently dusty in photos is in very good condition. has factory log books, rear blinds, and the paint just needs a buff.
  • S13 spec SR20det with brand new Extreme clutch,
  • Full S13 running gear with crossmember, steering shaft, power steering, etc.
  • Brand new HSD's in the front, never been driven on
  • FMIC and custom pipe work
  • Custom wiring loom, car is all running!
  • massive cooling system
  • Custom tailshaft
  • R31 complete rear diff conversion done
  • Fuel system in boot with surge tank and Bosch pump
Pics below tell the story. yes it is dusty and needs a clean up. has just been pulled out the shed. the car will be sold as an unfinished project but as mentioned above all that needs doing is an exhaust and then your set.
Price: $8000 ono
Contact Info:
Car is viewable at All Type Crash at 1395 Main North Road, Para Hills West during business hours. or you can contact Allan At All type Crash on (08) 8281 0130
For Sale
R32 GTS GTR carbon Nismo Trunk Spoiler - 200 x2
R32 GTS GTR carbon weather shields - $165 x1
RB26 valley and timing cover in carbon - $140 each or both for $250 x1
RB25/RB20 valley and timing cover in carbon - $130 each or both for $240 x1
R32 GTS/GTR carbon headlight duct - $190 x1
R32 vertex front and rear bar (2door rear bar) - $220 each or both for $400
R32 25mm vented front guards - $220
all items are brand new!
can post aust wide at buyers expense
0433 290 801
Hey guys got a AMPerformance dumpipe/frontpipe for sale came off my R33
$150.00
and x4 michelin pilot sport 245/40zr 19. 70-80% around 4-5mm above wear bar on 2 and about 3-4 on the other 2
$200.00
Located Parafield Gardens
Edited by Marky88
Nismo Front Camber Arms to suit R32
bushes are in good condition, The bushes in these are stiffer than standard
Non Adjustable type. , some of silver paint is coming off.
quick sale $70 NOW $50 >>>>will freight Aust wide (extra)
S13 SR20DET Gearbox
good condition
with shifter
$550
HKS Electronic Boost controller EVC 4
all looms and valve
$180 NOW $140>>>>will freight Aust wide (extra)
RB20 engine mounts rubber $20
Call or sms only no pm
can pick up Tee Tree Gully area
Paul 0422444532
Edited by DR30RSX
$150.00
$200.00
Dumpipe/frontpipe sold pending payment
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
