Well it's come time to sell my Stagea
Its a june 2000 Build C34 Nissan Stagea, 93,000km and still has a couple of years left on its warranty
It has the Full Dayz bodykit including the carbon insert in the front bar, carbon mirror covers, carbon "d" pillar covers and taillight covers
Engine is still the standard RB25DET Neo, running standard boost control and just a Blitz pod filter
It has a 3" bellmouth Dump pipe, 100cell Stainless highflow cat and a full 3" system finishing in twin 3.5" tips
Auto trans has been fitted with a shift improver kit by MV autos and had a full service and attesa bleed
The tiptronic shift on the MOMO steering wheel is awesome
Rolling on 18 x 9.5 +20 Enkei rims with brand new tyres, Whitlen adjustable rear sway bar and R33 GTR dampner adjustable front shocks
Fitted with a 1250kg towbar it bulls my boat with ease. Great family car, fun car thats practical but still surprises some at the lights
$15,499 ono
I can remove items to make it cheaper, I still have all the standard parts in the shed (ie rims, sway bar, quiet exhaust, compliance cat, shocks,etc)
Pm me for further info
  • Like 1
Hi guys. Thinking about selling my Nissan Stagea to get a 4wd with a larger towing capacity. I will consider SWAPS for a 4wd, after a dual cab as a minimum so dont tell me about your utes or commodores/falcons. Prefer a Cash sale
  • -Nissan Series 2 RS4 Stagea - Snow Edition with lockable centre diff
  • -Tiptronic auto
  • -140K kms
  • -Neo Rb25det, had factory nissan 100K service done by Nissan. all new belts, pumps etc etc, very well looked after and maintained
  • -New CV's fitted to the front both left and right
  • -R33 Brake upgrade.. stops way better then a stock stagea.
  • -wheel alignment done last week
  • -Dayz sideskirts and rear wing fitted
  • -Bleed valve and boost gauge, running 11psi. goes very well
  • -D&T exhaust system - have reciepts
  • -Tow bar fitted. have towed my race car + trailer + full car of people + fuel and tools + tyre rack with no drama's does it very well
  • -Tein Wagon Master coilovers. near new, have the reciepts, manuals and adjusters for them. handles great!
  • -18inch Speedy wheels all round with Federal 595's up front and neutons on the rear. plenty tread left
  • -3 months rego
  • -Pioneer MP3 player with a full set of awesome speakers/splits. sounds great without being over the top
  • -ALL electrics work
  • -inside and outside is immacualte!
  • -Recently fitted a triple point alarm/immob which complies with Aust standards and insurance worth $700
  • -have a stack of reciepts for the various work done
Price - 11K ono or swaps as above in bold.
Pm me or call/sms me for info. 0412 938 933
Some pics.
For Sale: 2x 25mm Bolt On Hubcentric spacers with all nuts $100 Firm
I'll take them if they are 5x114.3. I can pick up on sat when i'm in Adelaide, tho may be able to get my 'rents to pick up earlier if required
For sale from R33 S2
- Silver rear wing - $200
- Side mount intercooler with elbow pipe - $30 ono??
- R33 S2 ECU - $100
- Greddy turbo timer - $30
PM for details
Need this stuff gone asap, make an offer
pair of 27mm spacers $100 firm skyline 5 stud pattern.
R33 Genuine GTR grill in white $250
R33 fibreglass grill white $100
r32 4door skirts an pods plastic, brand new never fitted $600 set
rb20 cas $50
R33 brand new clear side nissmo indicators $100
Fuel setup new, Bosch 910, bracket and swirl $300
R33 tailights black $50
Edited by PROXIMITY
Bride racing reclinable seat for sale,no rips and no fading so still that nice dark colour - $850 neg with rails suit s13/14/15 r32/33 need it gone this week
Contact via SMS 0401475561
Cheers sam
THIS NEEDS TO GO $750 AND IT'S YOURS!!!!!
MSD digital rpm window switch.
used to control things like VCT, thermos, water spray or anything else you want to turn on and off at desired rpm.
this unit is all digital so press a button to set the rpm in 100rpm increments.
its pretty much brand new with box and instructions.
$100 (cheap)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
