For sale
Sa belt 4 point harness , black with shoulderpads
80$ono
Rb20 turbo no play. Can cometh dump/front/elbow .60$ono
R32 catback exhaust big hap system with cannon not too loud good street exhaust.150$ ono
Gutted 3" cat 30$
R32 back seats 80$
All boot trim and carpet make an offer
0435163144 plz text or call coz I don't check pm's
SHED CLEAN OUT
All items located in the eastern suburbs near Norwood
1. RB25DET coilpack/valley cover $30
2. RB25DET Standard front/dump pipe $30
3. S14/S15/R33/R34/Stagea Rear Camber arms with bushes $20
4. S14/S15/R33/R34/Stagea Rear Toe arms with bushes $20
5. Redline Shockproof Lightweight gearbox oil 2 x Quart bottles $20ea
6. OBD 2 Consult to serial cable w/ Belkin Serial to USB adaptor $80
7. Set of 4 tein coilover bump stops $10
8. RB25DET Side mount intercooler $20
PM ME
SHED CLEAN OUT
PM ME
redline oil is in the bin thanks to my old man.... :/
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
R33 gtst rear bar with gtr pods both will need repair $50
r33 gtst sr1 power window motor regulator LHS $80
r33 gtst sr1 power window motor regulator RHS $80
R33 gtst rb25det hicas computer $60
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project)
ARP rb25 Exhaust Manifold Kit new never used $100
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
dave
r33 s2 complete doors - white
r33 gtr front grill brand new never used
nismo steering wheel with boss kit
veilside bodykit to suite r33 s1
4inch cat back exhaust with 5 inch cannon (exhaust is cut in half) has no muffler or resinator straight piping sounded insane
offers for anything pm me
can you please add a price that you hope to get for these parts
Thanks
sorry, dont even know really
grill - 160 or so
doors 125 each or 200 for both
cat back exhaust 100
steering wheel 75 or something
bodykit 150
dohmar ill send u a pic tonight when im home from work, if u wanna pm me your mobile number i can probably send you one during the day.
cheers
items FOR SALE:
  • Twin tip straight pipes made from high grade stainless steel $150 firm designed to be flanged under the sub frame/ diff originally came from exhaust technology. very good quality pipes. suits R32.May suit other Nissan models.
  • Standard r32 GTS-T series 2 steering wheel (rare with leather horn button not plastic black one) mint condition no rips or tears,stitching is perfect $150 firm best you will find pics on request.
  • Standard r32 RB20DET injectors x 6 $100 firm come complete with o rings and seals, came off my 20 for GTR injector upgrade last kms was about 115,000. Good condition no leaks.
  • Midnight blue R32 GTR front bar (not N1) genuine plastic with genuine un cut GTR reinforcement, factory mesh and number plate bracket and custom made tow strap fits between lip and bar $600 firm will not split. sold as a package.
  • Original side repeaters mint condition on fascia sides x 2 one has broken top clip supplied needs plastic welding $100 for both or $50 each. Not supplied with globes and holders.Suits replacement.
  • Genuine din pocket with spring loaded front cover flap fits in center of dash near climate control and cd player. suits r32 skyline $30 mint condition
cheers guys please call me or text me on 0421675373 if there are any questions or interest. Im not on here alot anymore :(
regards BEN.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
