RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $60
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts complete $50
R33 gtst sr1 air con units that sit behind the dash, heater cores $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $10
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 rear window $50
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40
R33 gtst false rear wall $20
RB25det stock dump on black vht $20
R33 gtst rear bar, will need very small repair to $25
r33 gtst sr1 power window motor regulator passenger side $70
R33 gtst rb25det hicas computer $50
ARP rb25 Exhaust Manifold Kit new never used $100
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20
Rb25det sr1 cas with bracket $50
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
Dave
Momo Race wheel & boss kit in good condition (to suit r32's, was on a gtr)
$150.00
Apexi Pod filters & brackets to suit R32 GTR in good condition
$150.00
6 x Standard RB26 444cc injectors, removed to upgrade
$180.00
Located at Victor Harbor,
PM on here or sms / call 0415 117 115.
Rob
Hypergear TR43, Unknown km, came out of my 1999 R34 GTT with no issues at all with it, no shaft play, no smoke, bolts straight on, comes with V band and dump, oil line (everything in the picture). - $700
Turbo Information
R34 GTT Stock ecu Auto - $150
R34 GTT Stock Injectors x6 (Part number: FBJE100) - $100
RB25 Rocker Covers (Crinkle Black) - $60
Manual Boost Controller (think its an atomic boost controller) - $50
Greddy Profec b spec II boost controller, black in colour, has everything you need to put into your turbo car. working perfectly, no longer needed. comes with the box etc
price $350ono, can post anywhere in Aus for $10
Josh
0411742212
Turbo Information
Ecu Sold - Pending Payment.
Josh
0411742212
$300
Still for sale
Ive got a new stainless steel RB25det exhaust manifold to sell.
Clear-coated it in exhaust heat paint and wrapped it in thermal wrap. Since taken off the thermal wrap, and as such got some fibres stuck here/there.
Definately in as-new unused condition.
Cost me $300 a couple of years ago, sell for $100.
Decided to use the stock manifold and sell this aftermarket unit on.
Also, see my signature links below for a full-built RB26 R32 sedan track car, and my rebuilt Stagea - both for sale.
NOTE: I will be adding a Xtreme 6 puc button clutch to suit S15 on here shortly so once it's out in about 2 weeks I'll add it to the list below. Only done around 6,000 kms, cost me $1000 brand new. - Feel free to PM me anyway regarding the clutch. Reasonable offers considered.
Located in Southern Suburbs of SA.
Pickup preferred but will post if necessary.
No low-ballers please but willing to consider somewhat reasonable offers.
Reason for sale is because I have since upgraded and no longer require the current parts:
PRICE DROP: for S14 / S15 2nd hand Hybrid FMIC RS Spec - $200 ONO - Includes all silicon joiners and clamps!
Great for decent power gains required on a budget without much pressure drop.
Piping is damaged but will throw that in for free as I believe there may be missing pipes too (can only find 2 pieces since my last tune as tuners changed intercooler to a Blitz CS). Buyer is to arrange adequate piping for intercooler core.
Core was previously damaged due to the preivous owner incorrectly installing it, however it has been addressed with a weld and Epoxy. Doesn't leak any boost what-so-ever from the core.
If you are concerned it may leak then try some Expoy Multi-Metal from Sprint / Autobarn for $10, BUT I CAN GAURANTEE IT WILL NOT LEAK!
PRICE DROP S15: Unused Whiteline Subframe Bush set (Plus Polyurethane Type) - $150 ONO
Stiffen up that chassis and minimise that horrible Noise, harshness and vibration on your daily / track car!
S14 / S15: Unused and Unpackaged K&N Panel Filter - $80 ONO
Throw away that Ryco filter and get some air flow form a proven filter to provide better throttle response and economy.
Unused Nismo 1.3 Bar Radiator Cap - $50 ONO
Hold that pressure in for more effective cooling!
S15: Used Clutch fork pivot ball from an Xtreme Clutch set - $30 ONO
Previous owner had this installed on the car. You will want this if you have an aftermarket kit and didn't install the upgraded clutch fort pivot ball to minimise the load that's placed on the standard one.
2nd Hand Gearbox and Engine Mounts from an S15, OK Condition - Make an offer $?
8x NGK BCPR7ES to Suit Modified CA / RB Setups (will fit SR but not the preferred sparkplug) - $30 ONO - RELISTED
In regards to contacting, please PM me and we can go from there.
Cheers.
For Sale: Nissan Skyline R33 GTST , 5 speed
I have had this car for the past 4 years and it has never skipped a beat. Its the Ultimate Sleeper!
Complete HKS Hi-Power exhaust system worth 3K alone
HKS 2530 turbo!!
HKS FMIC
HKS Mushroom pod
Yellow Jacket Coil Packs
Exedy Racing Clutch
Whiteline Swaybar
Viper Alarm System
Very nice sound system, Alpine mono amp and 12in Pioneer sub, full tweeter setup
Serviced every 5,000kms since I've had it with Motul fully synthetic oil
Fresh 3 months registration
I simply dont have time to drive it anymore, Just started my own business and am quite busy atm
Price: $9,500 negotiable
Contact: 0433 088 889
PICS:
PRICE DROP $9,000 ono
For Sale R32 bits from a 2 Door
. R32 - Vented Fibregalss Front Guards in Gunmetal Grey. In pretty good condition. RH Guard has part of a Fibreglass GTR N1 kit on it and is sikaflexed on. $250 - $200ono for the pair.
. R32 2 Door - Fibreglass Side Skirts In Gunmetal Grey. Not the best condition. RH skirt is GTR N1 Style & LH Skirt is Type M. $60 - $50ono for the pair.
. R32 GTST - Front Indicators painted but look awsome on a dark color car. $70 - $60ono
Or take the lot for $360 - $300. Feel free to come and have a look at the parts.
Located southern suburbs. PM or txt for further info 0433 522 234
Cheers Tim
Price drop need these gone ASAP, need the $$$
Also for sale is a
Garrett 2530 with HKS .64 Exhaust housing. Turbo came off my rb20det, unsure of Km's on the turbo.
Turbo does not come with compressor housing, oil or water lines but comes with a Stock rb25 actuator.
I'm no expert on turbos but I suspect the shaft has more than usual freeplay. Turbo does not blow any smoke.
Some slight damage to compressor wheel
Feel free to inspect the turbo and see what you think.
Unsure of what the turbo is worth so i'll say $380ono
Located southern suburbs but I work in Wayville so I can bring parts to work for you to look at. PM or txt for further info 0433 522 234
D max carbon fibre bonnet $ 150
Origin carbon fibre boot lip $ 200
Vanquish roof spoiler $ 200
Origin rear bar $ 170
Origin side skirts $ 200
Origin front bar $ 100
Jap broadview mirror $ 30
Greedy sandwich plate $ 30
Greddy radiator cap $ 15
Greddy catch can $ 25
Cusco front strut brace $ 150
Cusco rear strut brace $ 150
Isc coil overs $ 800
Cusco rear camber arms $ 220
Kazama castor rods $ 220
R33 front lca $ 150
Gtr/projector? headlights $ 220
All to suit r32 2 door
More to come
lastly if you do not have money/low ball me don't waste my time or yours. Prices indicate condition. No I will not post photos of every item but pm me your email if a genuine buyer I will be more then happy to help.
Thanks
Up for sale is my R33 S1 Skyline. It is on defect and I know you can't sell the car while its on defect, but if someone wants a cheap car ready for the track for $12K you can take it off my hand as is with all the fruit. If you want to get it off defect than I will try and help out and sign the rego papers etc, you give me the cash, take it, get it off defect and enjoy it on the street.
Reason for being on sale is I have had enough. Best method of contact is to just send me a pm
FOR SALE:
Wheels brand STARCORP KAOTIC shadow chrome with machined lip 18x8.5 with FALKEN 245/40ZR18 tyres to suit R33 gtst.
Fronts are with good tread on rears need replacement but still driveable, rims overall are in great condition not a single scratch selling cz bought new wheels different style. $750 for quick sale.. picture below is borrowed but its exact model i got..
Resized640x480_100374%2020%20inch%20Starcorp%20Kaotic%20Alloy%20Wheels%20%28Medium%29.JPG
NEW unused carbon fiber vented bonnet r33 gtst series 2.. bought it for $800 now selling for $600
R33%20GTS-T%20VENTED%20CARBON%20FIBRE%20BONNET%20BODY%20KIT%20AERO%20KIT%20AERO%20.JPG
Also got used genuine front left side control arm and also left hand side caster radius rod bracket selling due to lack of knowledge in some of adelaide's work shops.. both for $100 or $50 each.. (pics for this 2 parts on request)
located near Salisbury
Txt me anytime for any question 0415440332 cheers :)
