s2 rb25 (not neo) splitfires with braket and loom - $450
r34 GTT front brakes inc: calipers, rotors (dba4000 slotted), pads (a1rm). rotors and pads under 500kms old - $600
eboost boost controller with solenoid, wiring and vac hose - $300
99% brand new r32 gtst BC br coilovers - $1000
1.5L surgetank ($150), 044 pump ($200), magnaflow fuel filter ($150), lines and fittings - $300
r32 early style brick headlights (n1 looking without the brakets for n1 vent) with globes and wiring - $150
pm and i can txt pictures.
Rb20 starter motor $50
Rb20 BOV $30
Rb20 CAS $100
Rb20 inlet plenum $10
Rb20 turbo an manifold $200
Rb20 intercooler $10
Rb20 dump pipe $10
chrome sideskirts $20
15" alloys with tyres 4 stud 4x100 $80
hr31 passage window control unit (broken button still works) $30
rb20 valley cover $20
rb20 coil packs x 10 with mounting brackets unknown condition $40
RB20 AFM unknown condition $5
R31 S3 grill in black $10
Wastegate spring 38mm 3-4psi $5
fairly stock standard ceffy for sale.. asking $7400.
1989 black/purple
factory manual rb20det
84*** on the clock
17x8 work eurolines
hks pod
KAAZ 1.5 way
http://sa.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-cars-Nissan-Cefiro-A31-RB20DET-manual-W0QQAdIdZ358255815
R34 RB25DET Engine wiring loom x 2 $150
R34 RB25DET ECU (auto) $150
R34 RB25DET Air Flow meter $50
R34 RB25DET OP6 Turbo $550
R34 RB25DET NEO Engine cover $80
R34 RB25DET Air con Compressor $80
R34 RB25DET Air con lines (2 that bolt to compressor) $40 each
R32 Nismo Fr camber arms, (non Adjustable) $40
R32 RB20 Waste gate Actuator $50
R32 RB20DET Engine with TD06 19C(rebuilt around 5000k ago), 550cc Injectors (this is making 230KW@ 21psi on very safe tune) includes Turbo inlet, dump pipe, adjustable cam gears, has had new water pump and greddy timing belt, cam, crank seals, T/belt tensioner and idler, fitted around 5000km ago. engine is under 100,000km, serviced every 2000-3000km $3000
(NO WIRING LOOM, ECU, AFM, COIL PACKS) May sell with loom ecu and afm if get good offer. Power FC, loom modded with injector resistor, Z32
Still in car, will remove after deposit , fitted to R31
also have cooler piping to suit
R32 RB20DET Gearbox $600 from above package,
Paul 0422444532
Tee Tree Gully Area
stuff for free out of some 33 doors
drivers side- (dont have window switch or power reg motor)
door trim
mirror in white
glass
wiring, plugs, whatever is there anyone can have
passenger i have a full white door at this stage,
so take whatever you need/want
also have a left handed ESP guitar + line 6 amp, + leads and wah wah pedal, stand.. etc
will only sell if i get what i want - $1100
enquire for more details .
door stuff was out of an s2 forgot to mention
all i have left is a power window regulator from passenger door (these go for over 100 at a wreckers)
and the passenger door trim
extra stuff for free too
rb25 valley cover in standard black
the (condensor??) fan or whatever it was that sat in between head lights on a 33
and still for sale
nismo steering wheel with boss kit - 75 or seperate 50 for wheel 25 boss kit
r33 4inch exhaust 5 inch cannon cut in half atm $100
R32 RB20 Waste gate Actuator $50 SOLD
Paul 0422444532
Tee Tree Gully Area
have some tyres for sale, just some i have sitting around that im not using.
2x bridgestone potenza RE050A 215/40/18 80% $80
2x bridgestone RE001 225/55/17 30% $20
2x maxxis 245/45/18 50% $40
miss matched pair 215/35/18 90% $50
miss matched pair 235/40/18 50% $30
miss matched pair 235/40/18 30% $20
bike tyres Rears: bridgestone metzeler renn sports 190/50/17
Fronts: battlax bt-003 raing 120/70/17 $20 for pair 30%
can send pics contact nick on 0414450101. cheers
Edited by vhsle
Specs: WORK Varianza T1S - MSP (machine silver polish) http://www.workwheel...ory=24&wheel=50
Specs: 18x8.5F and 18x9.5R and +35 offset all round.
LEGAL tread on all four tyres, front tyres are 225/40/18 Yokohama Avid and rears are 235/40/18 Bridgestone Sneakers stretched for that exta low!
I bought these about a year and a half ago and there was only a slight marking to the insert on one wheel, since then nothing has changed, there are a few minor scratches here and there.
These wheels are really hard to get here and you won't see them up for sale often as I found when I was looking for them!
Rears will need replacing within a few months, but as stated they have legal tread.
Price: $2550 ono
Contact: 0404128656
Still got goodies left
R32 GTR PowerFC + hand controller
$800
R34 GTR PowerFC D-Jetro + hand controller
no MAP sensor kit, as new condition (plugged in, tested, re-packaged)
$950
Blitz Dual SBC boost controller.
The whole deal (dual solenoids, all the vac lines you should need, wiring and unit)
$300
Plus adding to it
4x R34 GTR wheels with centre caps
1 wheel has a tiny bit of rash (not done by me, but by previous owner), otherwise really good condition
Will not be coming with tyres
$1200
Pics able to be supplied on request
Contact via PM
GTR Wheels back up for sale, price drop
$1000 FIRM. No tyres on them. Need these gone!
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
