For Sale Thread
Cubes
Got some stuff sitting here doing nothing:
3inch cannon, unsure what brand, no dents or huge scratches but used not new. $40
Twin 3" straight pipes, 3" inlet also.
Bought for $120 a month or so ago and ended up with a stainless exhaust, so price is $120 firm.
N1 GTR spoiler "Carbon fibre look"
Cost me $300+ postage off Just Jap. Save on postage $300 pick up, Brand new!
http://justjap.com/store/product.php?productid=17338&cat=&page=2
2X 235/45/R17 Federal 595-SS, above wear indicator still good for a few skids $80 for both
Kicker 'comp' Sub & Amp. $300
Kicker Sub and Amp comes with all wiring and everything you need to hook it all straight up, sounded really good when I had it in the other car, has a proper Kicker ported box and all Kicker wiring also.
Selling for $330 at JBs (without full wiring kit, fuses etc I'll give you with it!)
http://www.jbhifi.com.au/car-sound-gps-navigation/sub-woofers/kicker/amp-sub-box-combo-sku-73622/
Was only used for around 6 months!
Pics:
[/quote
Bump!
R34 Parts For Sale:
Pink Label AFM - Perfect working order $50
R34 Airbox & Snorkel with a ryco panel filter $50
RB25det Neo Coil Packs - Perfect working order $80
Stock Cat - $50
Rubber Intake Pipe - $20
Stock Fuel Pump - Perfect working order $30
Front Seats - Will sell as pair only $200
Generic Parts:
Slip on spacers 8 or 10mm $10
1 din triple gauge mount $10
HKS Turbo Timer $25
Samsung Omnia Icon 2 I8000T Mobile with ac charger $120
Parts all located in Clearview (near Gepps Cross Int).
All Prices are ONO so make a offer,low balls will be ignored.
Pics/inspections available on request.
Contact:
PM on here
or
0432 838 323
Daniel
Edited by funki_munki
s2 rb25 (not neo) splitfires with braket and loom - $sold
r34 GTT front brakes inc: calipers, rotors (dba4000 slotted), pads (a1rm). rotors and pads under 500kms old - $600
eboost boost controller with solenoid, wiring and vac hose - $300
99% brand new r32 gtst BC br coilovers - $1000
1.5L surgetank ($150), 044 pump ($200), magnaflow fuel filter ($150), lines and fittings - $sold
r32 early style brick headlights (n1 looking without the brakets for n1 vent) with globes and wiring - $150
pm and i can txt pictures.
Blitz Nur Spec exhaust 3" stainless cat back to suit r33 comes with 3" cat $350
Tow bar to suit s2 stagea, comes with wiring plug and fittings $250
s2 stagea auto centre console $70
s1 sagea auto trans with MV automatics shift kit $400
AVS wheels 17x8 and 17x9 with 235/40 all round heaps of tread left $450
s2 rb25 550cc injectors in standard rail $350
Still for sale:
Sorry some of the pictures are as links, wasnt letting me post pictures properly.
New N Spec water pump (R33 GTR) - 200$ (Top in the picture - Unsure if it suits other models apart from R33 GTR) - Brand New in box
New East Bear clear front indicators (R33) - 150$ - Brand New in box
Indicators 1
Indicators 2
More info on indicators here
http://www.nengun.co...stal-indicators
Greedy Oil Catch Can - 150$ (Used for 1 month - comes with original packaging etc)
More info on catch can here
http://www.streettun...-/prod_342.html
Isotta Steering wheel Perfect Condition - with Boss Kit (came off Silvia) - 80$
Steering Wheel
Can call/text on 0408 370 576 - Pickup from Hindmarsh / CBD
Item: RB20DET Crossover pipe from a Ceffy (No spot for a BOV)
Price: Make a reasonable offer
PM me or txt anytime between 7am and 10pm on 0433 522 234
R34 Parts For Sale:
Pink Label AFM - Perfect working order $50 SOLD
R34 Airbox & Snorkel with a ryco panel filter $50 SOLD
Stock Cat - $50
Generic Parts:
HKS Turbo Timer $25
Contact:
PM on here
or
0432 838 323
Daniel
got a T25G i don't need anymore, good condition
turbo only no lines
$250 located in the Western Suburbs of Adelaide, will post at buyers expense
might swap for adjustable caster arms to suit S13
call Theo on 0411160974
R34 Parts For Sale:
Stock Cat - $50
Generic Parts:
HKS Turbo Timer $25
Contact:
PM on here
or
0432 838 323
Daniel
Pic of the left over items. Just a note,the seats are from a sedan not a coupe,pics of these shortly.
R32 GTR front seats - including adaptor for drivers seat to fit 180SX etc (can still fit R32 GTR) $600ono good condition
R32GTR Jap tuned factory computer - no speed limiter / boost cut lifted. Made 270rwkw with STD turbos at 21psi....perfect for the Garrett dash upgrade turbos! $300ono
5 Point Safety 21 Roll Cage (Half Cage) for R32 GTR / GTST. Blue padding, includes mounting bolts. $700
Bump it up!
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
