FS:
Bilstein coilovers suit R32
Medium stiffness spring rates (cannot confirm exact spring rates)
Great condition.
Only selling due to wanting stiffer coilovers to suit my application (drift).
$700.
NEED THEM GONE.
Hey... got some parts in the shed that I need to clear.
ca18det full engine loom= $150
S14/S15 struts with lowered King Springs= front and rear. Excellent Cond, pulled from a low km S15= $250
S14/S15 front struts with lowered King Springs. Struts are average cond but springs are good
= $50
I will get part number asap on the springs above.
From memory the fronts will also with RS-V Stagea's.
2 x New D2R 4300k HID Xenon globes= $20
2 x New D2R 6000k HID Xenon globes= $20
I will get pics up asap.
I can help with postage at buyers expense or pick up from Gepps Cross or Blakeview.
Stock parts from my R34 GTT
Doing upgrades and this stuff is no longer needed any more.
Radiator (no shroud) few bent fins,nothing major.
$80
Neo "Turtle Shell" Has been trimmed to allow for FMIC crossover pipe to fit.
$20
Neo crossover pipe.
$20
Neo ReCirc Valve (BOV).
$20
Neo Throttle body w/TCS unit (No TPS).
$40
Rb25det S2 TPS.
$30
Pink Label AFM. Excellent condition (will have plug for it when I wire up for my z32)
$60 or $80inc Plug
Stock Boost Solenoid.
$30
Stock Exhaust manifold.
$40
All Prices are ONO. Discounts for people that take multiple items.
Pick-up from Clearview 5085
Contact: Daniel 0432 838 323
Some bits sold, rest still needs to go.
Got a complete set of R35 GTR brakes for sale off our old white car (they havent been on it since mid 2011)
Thats front and rear calipers, AP Jhook disks (couple of sets, some well used, some still ok) and some Endless pads about 60-70% worn
Take the lot and have the best brakes you have ever seen on an R32,33,34 for $2500....
Pm me!
Probably Matt, I had some fitted to a Navara for a local guy.
Anything can be fitted to anything - no we wont do it - but can point you in the right direction of someone who will :)
Bring money - all yours!
haha
ill call past quickly on friday.
is pure blond still drink of choice?
house settlement end of july so then its game on;)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
