I got a blitz turbo timer sitting there with the better part of the wiring harness...
4pk of JD's n coke - 0433830055
Also looking at swapping my bilstein coilovers suit R32 with softer spring rates.
I want base height adj stiffer coilies which would suit drift application better.
Clearing Out Few Parts....
RB25DET SERIES 2
SPITFIRE COILPACKS
$350
RB25DET SERIES 2
SUPER SPARK COILPACKS
$250
R32 M-Spec Turbo Brake Kit Includes
Front Disks And Callipers
Rear Brakes Are Complete with Knuckles
Hubs,disks, callipers And Cables
$400
TWO R32 SEADAN EXHAUSTS
LEFT ONE 3INCH WITH HKS MUFFLER
$150
RIGHT ONE FULL STAINLESS STEEL NO BRAND
3 INCH ALL THE WAY
$250
Pick Up In Mansfield Park 0431 391 262 Luke
Genuine bride brix ergo reclinable with bride rail. Mint seat, no rips, no stains and no fake shit. $600
R32 GTR passenger seat with rail $180
Will swap with cash on top for a decent set of s13 coilovers
Pm for photos
Bayden Smith
Fs cusco s13/180 strut brace 120.
R32 strut brace 80
R33 HKS superr drager cat back 800 regency approved
Rebuilt steel wheel Rb25 turbo gd for 20 psi 500
T25 rebuilt 200
... Bare ca block and head head has valves n shizz in it 100
Rb25 Pwr steer pump 80
Neo inlet manifold 150
S13/180 doors both straight with windows and mechanisim 150
R34 gtt front rotors calipers 500
R32 gtr door trims n rear quater windows 150
180 sx tail lights n garnish 150 set
BN hydro handbrake 150
180 vertex front bar 150
Audio
Dls a6 mono 1200wrms $800
soundstream 2.560 350
kicker 300wrms mono 150
euroline style wheels 18x8/9 700
manray vertex vr5s 17x9.5 700 pair
japanese piaa racing rims 17x8/9 800 (maybe 9.5 will look)
rb25 engine needs new headgasket 74 thou ks $800
r32 gtr front guards mind condition $400
R32 rear cradle complete with ally spacers n lock bar $300
R32 front crossmamber with power steer $150
6000k h1 hid kit. 100 bucks
3" AM Performance high flow cat. stainless steel. good condition. 190 bucks
r33 gtr wheel with airbag. 50 bucks.
r34 gtt airbox with filter and snorkle 20 bucks
0458005624 [email protected]
I'll grab the airbox and snorkle off ya pm sent
Got a few bit sitting in the garage that I need gone.
R32 GTS-t drivers side front guard - dark blue. (Type with indicator.) $80
Pair of R32 GTS-t type m side skirts. (Need a bit of work) $50
R32 GTS-t/GTR rear bar - White. (One of the clips is broken but other than that, in good condition) $70
Shoot me a PM.
Still up for grabs :whistling:
coilovers
Pm for photos
Bride seat and rail sold..
R32 GTR seat $150
Up for sale is my 2011/2012 model ZR pro pocket bike that hasnt even been fully run in, needs to go through one more tank of fuel before it can be put to its limits, only riden it a few times at quite low speeds in order to make the run in process successful, this is a well built pocket bike not a cheap dodgey one, even has its own build plate/ serial No, this bike cost me close to $500 and due to other commitments i have had hardly any time to ride it so its been sitting there for a good few months, comes with many spare parts such as a stand, upgraded pedals, tool kit, fuel mixer bottle and ill throw in a free bottle of two stroke oil and new clutch that needs to be put in after the run in period, im looking for around $260 ONO
Heres a lil more about the bike below:
Engine Description Two Stroke Air Cooled
Engine Size 49 cc
Engine Power 4.2 HP
Engine Ignition Magneto
Engine Cutoff Kill switch
Transmission Centrifugal
Max Speed 40+ mph (weight dependent)
Fuel Gas & 2-Stroke Oil @ 25:1
Fuel Capacity 2.5 Liter
Running Duration: 2-3 Hours
Max Load 240 Pounds
Wheel Type Racing Slick tubeless tires 6.5" rim
Brakes Front & Rear Disc Brakes
Demensions L 37 1/2" x W 19 3/4" x H 20 1/2"
Dry Weight 36 Pounds
Frame/body style Steel Tubed Frame
For more info or photos contact me on 0402930153
Edited by SLY333
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
