FS - Starcorp Impuls 18 x 9.5 18 x 8.5 +38mm sit just in from guards on a 33 gtst, minor gutter rash on all 4 nothing too serious. bit of paint fade in centres, brand new yokohama tyres on all 4 only put on last week. asking 1100 ONO.
PMs only please
fibreglass bonnet in black for R33 GTST these go for over a grand new...
asking 600
willing to swap plus cash my way for a standard gtst bonnet, prefer black.
Hi Guys
Up for sale are original R34 GTR wheels , they are immaculate inside and out .
There is one scratch 2 cm wide on one wheel hardly noticeable but otherwise perfect they have 265/45/18 Ventus Hankook RS-3s
Rare tyres in Australia Amazing grip with 70% tread with next to no camber wear .
Looking at $1800 due to there perfect condition
Click on pics to enlarge
They are currently in Belair South Australia 5052 can Freight anywhere in Australia for added cost .
Thanks .
Mark
F.S.
Splitfire coilpacks to suit rb26/rb20 and series 1 rb25 $400
2x R34 N1 turbos (2860-7's), one is fine but the other needs to be rebuilt with new bearings $600
Turbosmart boost T $50
Delphi 1000cc injectors to suit rb26/rb20, they are low independence and straight bolt in. Brand new in the packets $500
0433943034
For sale
Sa
Brand new smoked/clear r32 gtst front indicators.
I do have all 4 chrome bulbs but I think the fitting is wrong, orange bulbs available too.
Never fitted, can post at buyers expense.
$150
PMs only please
asking 600
still for sale
bonnet still for sale too
got some r33 nismo clear side indicators for sale too PM with an offer
parts im after if wanting to swap or make a deal or whatever
r33 s1 bonnet
stock wheels (2 or 4) or meshies
400r rear bar
standard side skirts (2 door )
m spec front bar
rb25 turbo
z32 afm
gearknob
or any rb25/r33 parts
cheers
HKS GT2535 Full Kit for R33 RB25DET. Great condition with minimal shaft play and ready to bolt straight up to your GTS-T.
Includes turbo itself, elbow and silicone joiner/shield, all lines, basically everything you need to swap out with your standard turbo. I'll include some new turbo to manifold bolts. An easy 250-260rwkw with supporting mods.
$900 ono. Pickup from 5098.
z tune r34 gtr body kit,seat cover,interior carbon fiber bits $3000
hi,i have r34 z tune front bar,side skirts,rear pods and front undertray,superior seat covers ,carbon fiber bits as per photos .if interested please contact me on 0478104724 and am selling as a lot .thanks
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
