R33 suspension bits $50 for the following
Rear suspension shocks and springs
Rear camber arms stock
front wishbone setup
Front camber arms stock
front knuckles
Front brake lines
R32 rear strut brace $80
Rb20 crossover pipe with stock bov $20
Rb25 crossover pipe with stock bov $20
Decat r32/33/s13/180sx/s14/s15 $40
gktech bolt on lock spacer $20
Text 0421549607 for pics/pick up.
Hyper gears new r33 highflow 5000km old before i was t boned - $950 including braided lines
New version pfc and hand control have receipt from nengun japan - 5000km use - $950
Nismo 740cc inj 12,000km use - $500
Bosch z32 genuine including plug $200 5000km
Msg on 0406873001 based in w.a can post at buyers expense.
For sale
r32 stuff
Nismo strurs rsr springs 100
rear camber arms, front castor rods 20pair
hicas rack no tie rods 10
steering rack 10 leaking seals
rb20det stock turbo 100
r33 stuff
stock struts ang king springs 105mm min ride height with stock 16s 100
rear camber arms 20pair
Stock airbox and hks panel filter 50
stock series 1 airbag steering wheel 50
stock side mount intercooler 20
Swaps
17 x7.5 33os front and 17x8.5 38os rear volk cv pro wheels full set no centrecaps
FOR another set of 17 inch wheels of similar period, size and offset
If I find a match im keen to keep my tyres too as theyre brand new
my wheels are either a 2 or 3 piece wheel and only just have clearence with big front brakes but not enough for a rear big brake kit
Make me an offer on these items, I need to get rid of them for more projects=)
0423789155 al
Have the following g from a manual White Series 2 R33 gtst:
Pair of tail lights (unmarked, all wiring/bulbs etc)
Windows for both driver and passenger doors (glass only, no doors)
Plastic panel under door that says SKYLINE (driver and passenger)
Hand brake mechanism (leather, bracket and first section of cable uncut)
Brake booster and pedal mechanism (no BMC)
Seat belts no fraying, perfect recoil, complete with bolts etc (driver, passenger, all 3 tears)
Wiper stalk mechanism
Boot and petrol flap release mechanism (complete from lever/cable/realease latch)
Pair door ajar sensors
Pair rear camberatms and traction arms
Just want it all gone sell the lot for $80 or a cold carton of Asahi Super Dry will do.
Pair of GENUINE Bride DIGO-R seats and rails for R33 GTS-T, purchased from Japanese Import Spares 12 months ago, seats are immaculate, no rips/tears/stains etc, just a little dusty from car being in storage.
Selling due to going to Cage and Fixed seats.
Retail for $1K a seat, and $200+ per rail, selling for $1500 as a complete bolt in package. No separating the pair, nor the rails.
Contact Ben on 0439 888 043, or PM here, Car is in storage @ pooraka but seats can be removed and picked up from mod bury. Can also help with delivery.
Are they the super low rails?
For Sale
6boost steampipe manifold, highmount T3 flange, ceramic coated suit RB25
genuine tial 44mm gate (bought with the manifold brand new from 6boost)
stainless steel screamer pipe - not shown in my pics but I have it
Price $1200. Adelaide. Can post.
[email protected]
They're Lowest bottom mount rails bride make, they're pretty damn low. And I won't separate them from the seats.
Its all good i wanted the lot if they were the high one. It for my mrs car and she is tiny 46kg tiny lol she needs a few phone books
+++++STOLEN 2001 3 CT9A EVO 7++++++
Was wondering if you would be able to help me out. My friend got his 2001 3 CT9A EVO 7 stolen around April this year from Cambridge Street, Penshurst SYDNEY. The police have been absolutely no help and I was wondering hoping you could spread the word to see if anyone may have seen or knows anything!
Thank you so much!!!!!
These are the details:
Make: EVO 7
Model: GH-CT9A SNGFZ
Colour: White
Rego when stolen: JDM3VO
VIN: TBA
Chassis No: CT9A -0004702
Distinctive features: whole rear of the car is an EVO 9 body.
Any info: [email protected]
1779255_10152378223856954_1704581884173210403304_10152378223891954_7052076604887
  • 3 weeks later...
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
