Item: Autotechnica Race Seats
Info: Pair of reclinable seats. Black fabric material. ADR Approved when used with correct rails.
Condition: Brand new never used - only taken out of box!
Price: $380ono.
Contact: PM or 0434 242 324 - Richie
$300 anybody? need some money for ecu to run my new injectors!
clearing all my stuff to assist in the 100k sercive bill :)
H1 8000k HID globes $50 ono (1 of the balasts is no good, if some one eles has 2 thats having dramas let me know)
2x 12" subs, $50 each...
1x 12 inch sub box $35 or 20 with a sub
2 d1 drift dvds, $25 each
rb26 'peformance' radiator hoses $45
all 3 ancilary belts for an rb26, dayco! $25 each
little amp perfect for front speakers $35 i also have pos and neg wires ill chuck in ?
JVC Direct IPOD CORD!! $75 plug and play
rb25 stock intake pipe $=1x iced coffee (strong :ermm: )
Alpine head unit $50 works good came in the car but i put my old one in
sum ghetto boost gauge $= 1 iced coffee, needs vac hose
send me offers people!
Edited by chef_stagea
clearing all my stuff to assist in the 100k sercive bill :D
rb25 stock intake pipe $=1x iced coffee (strong :( )
Boost gauge
head unit
raiditor hoses all sold pending payment! need this stuff gone people!!!
H1 globes fit all 32, 33 AND 34, s13 s14 and i think s15 etc.. very cheep set of xenon spare globes!!! i cant use them coz the new stag has h4
keen dude, will have to drop by sometime and see if theyre fatty friendly. :wacko:
hey chef, what brand are the subs?
1989 Nissan Pintara Sedan model
- In good condition best daily ever
- Automatic
- Immobiliser
- CD player and speakers
- Working air con & heating
- Registered 'till early March
- Immaculate interior
$850 firm priced for quick sale
A/C gas ran out today so it needs a regas. PRICE DROP $800
call anytime 0422319720 first in first serve.
GIVE AWAY
r33 gtst standard springs (attached to some dead shocks)
pm me if you want them n pick the whole lot up, i don't have the time to take the springs off the shocks hence giveaway, if no one wants em by Monday then binski it is.
Hi guys,
I have some R32 Coilovers out of my car which I am returning to standard.. They are currently in the car and any buyers in Adelaide can come for a test drive, coilovers will then be pulled out that night for the buyer. They currently have 11,xxx km, I bought them with 5,000km straight from Japan and haven't had any problem at all over the last year of owning them.
KTS Coilovers
R32
12,000 km old
15 point damper adjustable
Base Height Adjustable
8kg front / 6kg rear
"Driving, Turning, Braking. Your damper system affects greatly these three driving cores. KTS has succeded in making the excellent one; we analyzed the data based on our sales & develoment achievements in order to handle the road surface conditions which change unpredictably.
Specification:
Shock is 15-way adjustable.
Plated Steel Shock Shell,
Adjustable Shock Length for Height Adjustment while Maximizing Stroke,
Pillow Ball Upper Mounts,
High Pressure Single Tube
Construction: A Double Oil Seal, Dust Boots, Bump Rubbers, Rust-proof, Overhaul Available."
Taken from "http://www.kts-web.com/overseas/product/damper/db.html"
Full coilover specs are listed here:
And KTS history listed here:
http://translate.google.com.au/translate?h...ww.kts-web.com/
Pics of KTS coilovers: (coilovers are still currently in car, so pics are taken from google)
$1,000 + postage
Edited by JiN_MaN
I have a set of RS*R coil springs to suit R33. Attached to KYB Buzz Spec adj. dampners. one rear was knocking slightly. Make me an offer.
Also have R33 std castor rods with super-pro bushes, make an offer.
SOLD!! Thanks Nigel :sick:
free!!!! to a good home in the drift sky
2 235 x 18 bridgestone tires with 75% tread minus the 10 mm bald
2 265 x 18 bridgestone tires with about 20-30% tread left
came off my R34 GTT
pick em up, tonight at villis for 2 and the other 2 are at sinergy in the cbd
need to know in a by 6pm if you want them brought to villis tonight ?
otherwise you can pick em up in aldinga
came off my R34 GTT
pm sent ! :sick:
hey guys i hav a s1 rb25det motor for sale which has a either blown head gasket or a cracked head there is water in piston six. Compression 1:100 2:100 3&4:90 5&6:100 engine is probly good for rebuild. engine comes with everthing minus turbo, coil packs and loom askin 400ono
s2 loom and ecu in ex cond. 150
s2 afm ex cond 150
6x s2 coilpacks ex cond 50
s2 turbo needs rebuild 50
call jarad 0423904934 or pm cheers
for sale:
rb25det s2 coilpacks $50 for the 6
apexi intercooler $300
200cc hummer pitbike, 19f/16r rims, low usage (ie near new)
battery start, lights, wrapped exhaust, spare flatslide carby
$500 as is
coilpacks sold and gone
want the intercooler gone - give me a decent offer and its yours
same with the 200cc dirt bike - offers?
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
