The controls on the R34 tiptronic steering wheel appear to be perfect for stereo controls. Up and down for the track selection on one side and up and down for the volume on the other.
Has any one does this before, installing a R34 tiptronic steering wheel onto their car and wired up the tiptronic controls for stereo?
I did a search and couldn't find mention of it anywhere. Why hasn't any one tried it? I think it is a great idea and would bring something modern/factory looking to a fairly old car.
Here is how I thought it could be done:
For example in my car I have a Pioneer headunit.
I would purchase a hard wired remote harness that uses resistors to control different functions. (ie. 18K resistance is volume up, 24K resistance is next track etc).
The tiptronic wiring in the steering wheel would get rewired with resitors put into each button.
Wiring from tiptronic steering wheel goes to hard wired remote harness on Pioneer headunit and hey presto, factory audio steering wheel controls for an aftermarket head unit.
Thoughts?
I've certainly thought about it but never seen a 34 wheel for sale, does it bolt straight up and is the air bag wiring the same?
As you've already said getting them functional should be simple enough, would be interesting to see how they are currently wired in the wheel, wether it's resistance or direct wired switches.
All Skyline steering wheels bolt into one another. To get the airbags to work the cars have to have the same amount of airbags. So for a R34 steering wheel, it can only function in a series 2 R33 with dual airbags.
As soon as I get some spare cash available i'll buy a tiptronic steering wheel and give it a go.
Will post up my results.
load it with V35 values. that makes interfacing to the deck easier. most of the jap units are 3.5mm input with an external interface for the wheel.
and yes I HAVE done it. didnt do a nissan though but a toyota.
use the resistance values for the V35 steering wheel. the FSM is on the net for the G35 and that is the sam thing where the SWC is concerned.
Oh ok. Hmmm I thought I would have to use the resistance values for the Pioneer hard wired remote?
These are the values I found after a bit of Googling. Will obviously have to double check they are correct:
8.8k Ω Seek up
12.1k Ω Seek down
16.8k Ω Volume up
23.6k Ω Volume down
  • 1 year later...
Sorry for digging up old post :P, but it is a very interesting topic.
I am also very interested to do a audio function conversion for my R33. I was wondering did you end up getting this to work?
Thank you
short version is yes. if you can find a later car with steering controls and COPY the resistance values across to your wheel then it will work.
  • 5 years later...
Bumping a massively old thread, but did anyone successfully get this working with an R34 steering wheel,?
Importantly, does anyone know if the wiring is available in the loom for R34 manual -to allow for those extra wires for tiptronic control?
Yep massively old thread !
But I don't see it being that hard as I've fitted a triptronic steering wheel to a S1 R33 and use the switches to run my cruise control unit ( pics some where on this forum ).
Best possible way would probably to use the remote control unit of the stereo, strip it and solder on wires to the volume control or other functions you want to run. Then find the plug the four wires that come out of the clock spring, (the fifth will be for the horn) that operate the plus/minus switches and solder them together and Bobs your uncle (unless he has the operation and then he'll be your aunt). The triptronic switches are momentary ones so I can't see why it won't work
Then all you have to do is box up the remote control and put it some where inside the dash with easy access for when the remote battery goes flat and you have to change it.
Clear as mud ? Then my job here is now done !
Good to hear about there apparently being separate momentary lines for each button - that makes things simpler.
So  I guess the only question for me is going to be whether the clock spring on a manual vehicle has a single line for just the horn, or the 5 lines for the 4 switches + horn.
My plan if that is true would be to wire up a box to take input from those 4 inputs, and output that into a standard way (perhaps as Chris said much earlier in the thread with different resistance values per button) - as that would make it easier to fit in with an aftermarket stereo.  Thinking about it then, you could even have different functions for long/short-press or buttons held together, and all sorts.  Something to mull over :)
Anyway, thanks for contributing!
I found this in another thread about removing the airbag -
I changed an R34 GTT steering wheel from auto to manual yesterday, this is a great help but I did come to a hurdle when I realised the horn wiring plug is different between auto and manual due to the tiptronic controls. A simple fix was to use the original auto horn wiring that screws onto the horn plate as there is a screw hole for it and simply breaking off the wiring for the original manual wheel as it is rivitted onto the horn plate. This also involves cutting the steering wheel control wiring which was 4 pin from memory. It's easy work to see which wires you need to cut as they will obviously be joined up to the tiptronic controls.
Which doesn't bode so well for the wheels being the same with regard the horn / clockspring - and I'd need to find an auto clockspring to change over as well to add steering wheel controls.  Sounding like a lot of cost & effort!
My car was auto and we wired controls into the steering wheel (i.e we had an aftermarket transmission ECU and wanted to use the shift paddles to actually shift).
The thing we noticed is after using the wiring "after" the clock spring (i.e not changing anything on the wheel itself or the clock sping itself) that the up and down on each side are linked. There's actually only two outputs to ground on the wheel as opposed to 4.
That worked well enough natively for us as we wanted "shift up" and "shift down" but without any detail whatsoever I remembered thinking/noting down that there was only going to be 2 functions that I could map to the wheel later, as I had visions of mapping it to launch control switches etc once the car was manual.
Car is manual now but I can't find a use for all the buttons anymore, I've made it all too simple :P
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
