The controls on the R34 tiptronic steering wheel appear to be perfect for stereo controls. Up and down for the track selection on one side and up and down for the volume on the other.
Has any one does this before, installing a R34 tiptronic steering wheel onto their car and wired up the tiptronic controls for stereo?
I did a search and couldn't find mention of it anywhere. Why hasn't any one tried it? I think it is a great idea and would bring something modern/factory looking to a fairly old car.
Here is how I thought it could be done:
For example in my car I have a Pioneer headunit.
I would purchase a hard wired remote harness that uses resistors to control different functions. (ie. 18K resistance is volume up, 24K resistance is next track etc).
The tiptronic wiring in the steering wheel would get rewired with resitors put into each button.
Wiring from tiptronic steering wheel goes to hard wired remote harness on Pioneer headunit and hey presto, factory audio steering wheel controls for an aftermarket head unit.
Thoughts?
I've certainly thought about it but never seen a 34 wheel for sale, does it bolt straight up and is the air bag wiring the same?
As you've already said getting them functional should be simple enough, would be interesting to see how they are currently wired in the wheel, wether it's resistance or direct wired switches.
All Skyline steering wheels bolt into one another. To get the airbags to work the cars have to have the same amount of airbags. So for a R34 steering wheel, it can only function in a series 2 R33 with dual airbags.
As soon as I get some spare cash available i'll buy a tiptronic steering wheel and give it a go.
Will post up my results.
load it with V35 values. that makes interfacing to the deck easier. most of the jap units are 3.5mm input with an external interface for the wheel.
and yes I HAVE done it. didnt do a nissan though but a toyota.
use the resistance values for the V35 steering wheel. the FSM is on the net for the G35 and that is the sam thing where the SWC is concerned.
Oh ok. Hmmm I thought I would have to use the resistance values for the Pioneer hard wired remote?
These are the values I found after a bit of Googling. Will obviously have to double check they are correct:
8.8k Ω Seek up
12.1k Ω Seek down
16.8k Ω Volume up
23.6k Ω Volume down
  • 1 year later...
Sorry for digging up old post :P, but it is a very interesting topic.
I am also very interested to do a audio function conversion for my R33. I was wondering did you end up getting this to work?
Thank you
short version is yes. if you can find a later car with steering controls and COPY the resistance values across to your wheel then it will work.
  • 5 years later...
Bumping a massively old thread, but did anyone successfully get this working with an R34 steering wheel,?
Importantly, does anyone know if the wiring is available in the loom for R34 manual -to allow for those extra wires for tiptronic control?
Yep massively old thread !
But I don't see it being that hard as I've fitted a triptronic steering wheel to a S1 R33 and use the switches to run my cruise control unit ( pics some where on this forum ).
Best possible way would probably to use the remote control unit of the stereo, strip it and solder on wires to the volume control or other functions you want to run. Then find the plug the four wires that come out of the clock spring, (the fifth will be for the horn) that operate the plus/minus switches and solder them together and Bobs your uncle (unless he has the operation and then he'll be your aunt). The triptronic switches are momentary ones so I can't see why it won't work
Then all you have to do is box up the remote control and put it some where inside the dash with easy access for when the remote battery goes flat and you have to change it.
Clear as mud ? Then my job here is now done !
Good to hear about there apparently being separate momentary lines for each button - that makes things simpler.
So  I guess the only question for me is going to be whether the clock spring on a manual vehicle has a single line for just the horn, or the 5 lines for the 4 switches + horn.
My plan if that is true would be to wire up a box to take input from those 4 inputs, and output that into a standard way (perhaps as Chris said much earlier in the thread with different resistance values per button) - as that would make it easier to fit in with an aftermarket stereo.  Thinking about it then, you could even have different functions for long/short-press or buttons held together, and all sorts.  Something to mull over :)
Anyway, thanks for contributing!
I found this in another thread about removing the airbag -
  Quote
I changed an R34 GTT steering wheel from auto to manual yesterday, this is a great help but I did come to a hurdle when I realised the horn wiring plug is different between auto and manual due to the tiptronic controls. A simple fix was to use the original auto horn wiring that screws onto the horn plate as there is a screw hole for it and simply breaking off the wiring for the original manual wheel as it is rivitted onto the horn plate. This also involves cutting the steering wheel control wiring which was 4 pin from memory. It's easy work to see which wires you need to cut as they will obviously be joined up to the tiptronic controls.
Expand
Which doesn't bode so well for the wheels being the same with regard the horn / clockspring - and I'd need to find an auto clockspring to change over as well to add steering wheel controls.  Sounding like a lot of cost & effort!
My car was auto and we wired controls into the steering wheel (i.e we had an aftermarket transmission ECU and wanted to use the shift paddles to actually shift).
The thing we noticed is after using the wiring "after" the clock spring (i.e not changing anything on the wheel itself or the clock sping itself) that the up and down on each side are linked. There's actually only two outputs to ground on the wheel as opposed to 4.
That worked well enough natively for us as we wanted "shift up" and "shift down" but without any detail whatsoever I remembered thinking/noting down that there was only going to be 2 functions that I could map to the wheel later, as I had visions of mapping it to launch control switches etc once the car was manual.
Car is manual now but I can't find a use for all the buttons anymore, I've made it all too simple :P
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
