Item Summary: 1993 NISSAN SKYLINE R32 gtst, R32,pain,t kit, offset rb25det , 25 box
Postcode: 2340
Odometre: 117,000 kilometres
Asking Price: $5,000
Condition: Used
Reason for Selling: money
Delivery Methods: PickUp
Contact Info: Justin 0423226950
Extra Information:
I would rather money at the moment so car is for sale $5000 for the rolling shell or $8500 with motor and box
R32 gtst
kia yellow/green colour
vertex kit
front fibreglass widebody gaurds
half cage ( if not sold seperatly before)
e-boost boost controller
a/f gauge
deep dish steering wheel
koya 17x9.5 +15 offset brand new tyres
vynal interior
front strut brace
front adjustable caster arms
subs amp cd player
engineered for motor box suspension intercooler etc... (rb20 engine number)
$5000 will get u this (paint and body work cost $3500 alone) OR that and all this
rb25det with plenum wiring and loom
rb25 gearbox
custom tailshaft
speedo conversion
fuel pressure gauge
new standard clutch
for $8500
probley forgot something but will post it if i remember i invite anyone to come have a look u will not be diapointed i have a few pics but they do not do it justice if i pull it right out of the carage i cant push it back in ( there is a photo with with it on the trailer between when it was painted and the motor was put in ), motor and box is in it just need battery and injectors power hooked up hasnt been rego'd since conversion was done rear bar has a primed section it just needs paint sprayed on it paint can be supplied.
Any questions just ask no really after swapsunless there is a far bit off cash my way or maybe celsior and cash my way
https://www.sau.com.au/forums/topic/354193-93-r32-yellowygreen/
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
