For Sale
1989 R31 Nissan Skyline
4 Speed Automatic 6 Cylinder 3 Litre 213 thousand K's
Very good Condition
Engine Runs, Just needs battery and Radiator as i have taken them out for my other car, otherwise rest of engine bay is in good condition. car was run about 2 months ago before i took those things out and it started first time, just needs those things replaced
Has power windows, power mirrors, power sunroof, air-con (very cold), power aerial and cruise control - all work very well
Automatic transmission shifts well, car also comes with a cd player/am fm radio.. all works well
Velour interior, very good condition no rips
White paint all over car is very good, has a silver bonnet as i replaced the white bonnet that had a severe ding in it, havent got around to painting the bonnet white yet but once it is painted car will look as new!! *Please note the photos above show the car with a white bonnet, i can supply photos of the car with the silver bonnet if you want but essentially the car looks exactly the same as above, just with a silver bonnet.*
lowered suspension in the front, rear suspension was leaking so replaced with standard suspension just so it will be in driving order,
car has been off the road for about a year as I purchased another car and this one has just been sitting in the backyard doing nothing.. interior is a little dirty but i have given the car a clean so it may just need a detail for the picky owner..
No RWC or rego to be supplied, car is being sold as is, where is..
car is on ebay.. no reserve auction so grab yourself a bargain.. Link Below
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=200577175265#ht_802wt_932
any question ask below or pm me..
good luck guys!!!
https://www.sau.com.au/forums/topic/354231-qld-r31-nissan-skyline-ti/
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
