Hey guys
Iv had my r33 s2 for bout 6 months and for the first 4 months it ran sweet. But all of a sudden it developed a miss so the first thing I did was turn my boost down to stock levels as it was at 10psi. This didn't stop the miss, oh and I had just recently done a service on it and changed the plugs and gapped them to .7.
Over a few weeks it got worse so I found some second hand coilpacks from on here and the guy who had them said they worked fine at 14 psi for him.
Why is it that now after a few weeks of having them in it is still missing?The miss was not as bad when I first put the coils in and it would take more boost around 10psi again but it has died off and has started to miss like bitch again. I'm planning on getting some yellow jackets or spitfires in a few weeks but if you guys have any clue as to what else it could be any help would be awsome! My list of mods are
3" exhaust
Fmic
Blitz dual sbc
Apexi afc neo
Pod filter
Pleeeze helps me I don't like having no powers!! =[
https://www.sau.com.au/forums/topic/354236-whats-causing-my-missfire/
S2 don't have an ignitor. Does it miss when idling? If so, you should be able to narrow down which cylinder is missing by unplugging each coil pack individually in turn. Then when you have found the one that didn't worsen the idle from unplugging it, you can swap it with a coil pack from a different cylinder to see it the problem moves with it. If the problem moves with it, Bingo! You've solve the mystery. If the problem remains on the same cylinder then it means that something else is the issue like possible injector problem or coil pack loom etc....
It does miss a little on idle but it is bad under load. I use Bp ultimate. The plugs are coming up 5000 ks and can't remember what plugs I'm using think they bcpre6 or something like that
Hey mate,
I'd make sure you have the platinum or similar spark plugs which are about $23 ea first.
I'm having a similar problem to you though. Although mine happens under load not on idle, idles fine. you can take your coils out and get some good insulation electrical tape (not cheap shit) and tape 3 or 4 layers over the stem of the coil as they earth out somehow. I did this with mine but its still missing under load but not as bad. I advise to get someone you know who has good coils and try them in your car. Then you can eliminate the coils. As far as i know the stem earths out under load aswell as the maind part breaks down. I think mine are breaking down at the main part. Im getting some coils off a guy in QLD and i hope it fixes the problem..
If not it could be the coil loom. Its just a process of elimination which is easy as you can do it your self ;)
Also what ECU are you running? stock?
I'm running a Wolf 3D ver 4 which isnt the best but i know it has been tuned to 310HP when i first got the car so the computer isnt the issue with mine.
Hope this helps dude.
Kier.
Edited by yye-33w
Yeah mine happens under load as well just on idle it skips every now and then so no miss on idle. Yeah got stock ecu i have added front mount and recirc blow off valve since getting the car so it could probably do with some adjusting on the afc neo but I will go over things on Sunday and see how things look permitting its not bloody hot!! What plugs do you recommend using kier?? Cheers for the feedback fellas
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
