hi just selling my 1995 R33 Gts25t series 1 in white colour..Owned the car for just over 6 months never had a problem with it...Selling due to travelling to tafe and uni is too far for me to drive in a skyline 4 days a week...
The car has 114,000km's on it...at 110,000 i had a major service done..including timing belt, water pump, all drive belts, oil, oil filter, coolant flush etc... all running perfectly except one of the belts whistles when it first starts up (needs to be tightened). The car had new disck brakes and pads put on it at 105,000kms and also at the same time was taken to matouks racing for a re tune. The car makes 210kw atw at 10psi (driven on 7psi mostly).
The car has a full 3" "inch exhaust system, k&n pod filter, front mount intercooler, Blitz dual stage boost controller, and the re tuned ecu by matouks racing.
Interior condition is immaculate!
Exterior has usual light scrathes marks but very good considering the age of the car..
Selling for $8,500 NON NEGOTIABLE! dropped it down from $11,000 as a buyer fell through at $10,000 due to a loan issue.
I bought the car late 2010 for $10,000 and have spent just over $1,500 on it so it owes me a bit..However 8,500 is a loss that i can handle...my loss is ur gain...
contact me anytime, call or msg
Nikita
0433 793 100
https://www.sau.com.au/forums/topic/354260-95-r33-gts25t-skyline-for-sale/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
