HI All,
Just seeing if there are any expressions of interest as I am thinking of selling my Holset turbo.
I bought it last year with a view to fitting it to my R33.
After some consideration I think I will pursue a different path.
It is an HX35 Internal Wastegate model Turbo. (includes wastegate actuator)
These turbos are in reasonable demand as they are a genuine alternative to large frame Garrett turbos. 'Ceffie' posted a thread on this board about these turbos and his experience running one on an RB30- power in excess of 300rwkw @ 1 bar of boost is typical.
So.. the details:
It has the 12cm' rear housing
4" Compressor inlet with anti surge porting
V-band Compressor outlet
Oil only, no water cooling.
Turbo has almost zero shaft play.
I have partly disassembled the turbo for inspection and it appeared to be in good shape, no corrosion or rust.
Turbine and Compressor wheels/ blades are in perfect condition.
Looking for around $350 for the turbo.
I can supply it assembled or disassembled.
I have attached some grainy iphone photos of the turbo fitted up to an RB25 manifold. Can supply more photos on request.
Cheers!
https://www.sau.com.au/forums/topic/354278-eoi-holset-hx35-turbo/
Couldn't edit the first post so ill add some things i forgot!
Journal bearing core
Exhaust inlet flange is twin-scroll T3- will bolt on to standard RB25 manifold (with a 20mm spacer)
Here is the thread i referred to above:
http://www.skylinesaustralia.com/forums/topic/271404-holset-hx35w-installation-in-standard-low-mount-position/
The build quality on this turbo is amazing. Every part of it is built with longevity in mind!
does it come with oil lines etc??
Turbo does not come with any oil lines.
Hey mate I'll take it at 170 shipped to melb that's about what they are worth
Thank you for the wisdom you have brought to this thread. I kindly reject your offer.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
    • Shit. Starting to look like a car again.
