I have searched for nearly 5 days straight every night, and came to the conclusion that although a lot of people want to know which wheel bearings fit, no one actually gave us hard evidence or even a personal account of which ones do.
This is what they should look like: note the handbrake bracket.
Courtesy of this guy (Eu Jin): EJ's ER34.blogspot
Nissan FAST reference Part No. 43210-AA100 does NOT fit.
It looks like this; and is cross-referenced with S13/S15 numbers
Nissan Part Numbers 43281-AA100 for the left side and 43280-AA100 for the right side - also do NOT fit, they look the same, but the centre hole is larger, requiring a custom spacer ring to mount them. (note: the separate part numbers only mean that the screw in the bracket changes from one hole to the other)
'Elite Racing' in topic "R34 Gt Rear Wheel Bearing - Part number?"
The part number you should be looking for is 43281 AA100 (see above) or 43281 AA000 but I don't have your VIN so it's not gauranteed.
- there was no confirmation either way on that second number.
CBC in Regency Park, South Australia quoted part number NJ246-A to fit R34 GTT (RWD).
This is suspiciously similar to the NTN part number Just Jap quote: NTN-NJ246A Just Jap Site
However, 'DECIM8' in the same topic as above:
I replaced one 1 year ago with no external replacements. I tried CBC they sent the wrong one. You need the whole assembled part. ...
With 4 different numbers from Nissan and 3 of them confirmed wrong, and one unconfirmed...well, I'm not sure I want to pull my daily to bits just yet, and it desperately needs doing.
Has anyone experienced success, personally, finding a DIRECT REPLACEMENT rear wheel bearing for an R34 GTT (RWD), and if so please post here, with supplier and part number.
Edited by nato_wp
  • Like 1
https://www.sau.com.au/forums/topic/354327-r34-gtt-rear-wheel-bearings/
hey mate. can u not just give your vin number to nissan spare parts and they get you the right bearing?
EDIT *keep in mind i have NOT read your other threads so u may have already tried this and it isnt so easy*
Edited by tm_r33
Im busy replacing mine rear wheel bearing also on my Skyline R34 GTT. I got the parts 43281-AA100 for the left side and 43280-AA100 for the right, and as u said its larger, but not a big difference.
I think maybe the wheel bearing assembly hub got smaller cause its been pressed with the old one. Maybe if you get a new one it would be the same size as the wheel bearing,
Maybe im thinking too far or going crazy here...:P . Im also been searching around for answers. Might even order a new hub to see if it might work.
  • 1 month later...
Well I found out the solution !
You have to buy a new hub also and press it to the bearing.
So the bearing number 43281-AA100 & 43280-A100 are correct.
And the Rear hub wheel would be : 43202-85F00
The new hub would be maybe just a little 0.5 mm wider than the old.
  • 6 months later...
  • 10 months later...
  • 1 year later...
I got a replacement part from CBC Bearings, fit perfect.
Part Number - NJ246AKIT - $114.58 + GST. The part suits left or right, you have to punch out the pin that locates the handbrake bolt and install it onto the new bearing assembly.
I'll post up a detailed thread for future reference.
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
