22 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi guys. I'm really contemplating on whether or not I should lower my R34 Gt-t.
They definitely look alot better when lowered a couple of inches, however the pain of having to drive extra slow or even avoiding speed bumps alltogether doesn't sit well with me. I like that I can drive just about anywhere and don't have to worry about small curbs in car parks etc.
I bought my car stock standard. The front bumper has no scratches/dents/scrapes on it which I'm really pleased with and hope to keep it that way. However one thing I don't like is the visible muffler that can be seen due to my car being a few inches higher.
I know its a weird question but what are your guy's opinions? Do you find your front bumper gets wrecked easily with a lowered car?
Here's a pic of my car, does it look ok as is? Should I lower it?
https://www.sau.com.au/forums/topic/354333-lowering-an-r34/
lol @ the voting.... that made my day, lower your car by about 30-40mm, that suits the r34 alot, my mate dropped his car on d2 or d4 coilovers, and the ass is so low, even on the highest settings, that this car scrapes everywhere. the front is a good height though and doesnt hit or scrape on anything.
as long as you get a nice setup with springs and shocks or coilovers and get it all aligned and adjusted properly, you wont have any problems....... except for the usual cop stopping you
https://www.sau.com.au/forums/topic/354333-lowering-an-r34/#findComment-5676430
preferably you want a little rake from front to back, like maybe 10mm? so the back is a touch higher than the front.
if you're planning on changing rims, factor that in to your suspension choice.
ideally you DON'T just change springs as the standard shocks most likely are not up to the job if you want a proper handling car. Either do both springs/shocks or coilovers or don't do it.
i ran Whiteline springs and Bilstein shocks in my last GTT and they were fantastic. I believe there are some decent coilover options around now, but they'll just be decent, not fantastic as there are quite a few entry level options.
You get use to being careful with the front bumper. I had about 8cm's clearance on the front of my GT-T and still managed to not destroy the front lip, just take a bit more care and angle angle angle.
SWAYBARS FIRST though!
https://www.sau.com.au/forums/topic/354333-lowering-an-r34/#findComment-5684184
hey ur the guy who had that sweet black GTT for sale......... is that ur new car, it looks awsome, can u please send me a link to some pics :thumbsup:
EDIT: oh and definitly lower it :thumbsup:
Edited by ML73ZR
https://www.sau.com.au/forums/topic/354333-lowering-an-r34/#findComment-5684776
Where is the "no" option?
I'm going to go agasint the flow & say that if you are using it as a daily car that gets driven to a lot of sh*t places (with crap roads, massive speed bumps etc etc like me) then I would keep it @ stock height.
Even my own driveway is on a stupid downward angle & my stock height car just manages to clear it without scraping the underside.
*puts flame suit on* :ph34r:
https://www.sau.com.au/forums/topic/354333-lowering-an-r34/#findComment-5684817
just don't lower it to the point that your front right tire rubs on the plastic inner. why you ask? because the main wiring loom is just under it and when you rub through it your whole wiring loom catchs fire. just a little hint for ya!!!!!
actually it doesn't catch fire, but your wipers and headlights may come on whenever you corner right.
https://www.sau.com.au/forums/topic/354333-lowering-an-r34/#findComment-5689708
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
