  • Replies 106
Terry, thanks! I think that's a real great compliment!
Nice Bayside Blue R34 you have there! Closest i ever seen was my 1/18 scaled model that I had that I sold off before flying to Perth.
NA_Goodness, I'm using my 17 - 50mm Tamron and 50mm f1.8 canon for most photos, with a 28-105mm in my bag , hardly use it to be honest.
Sticking to my 50D till I can afford a 5D Mk2
How do you find the Tamron lens? I love my Canon 50mm 1.8, and have a Canon 17-85 and 70-200mm f4 L as well.
It's pretty decent. Most of my photos' taken with it so you'll be the judge.
It wouldn't be as clear as a L lens, i was considering this or the Canon 17-40 L lens.
How much does a 70 - 200mm F4 L cost in Perth?
A 2nd hand piece costs around AU$620 in Singapore
Edited by E3lipse
  • 4 weeks later...
Hi mates
Looking for a Bayside Blue or White R34 GTR to shoot. If anyone knows of an NSX , i would be real happy as it's the one of the last Hondas I've been looking to document through my camera (and a Prelude...)
Feel free to PM me to discuss.
I know someone with an old NSX but not the facelifted last model, and you can shoot my R34 if you want :)
Hi Stephen, I've received your PM , I'll send you my number shortly :)
A TVR? There are TVRs here? Bullet holes inclusive?
really nice pics pf two gens.you know there's potential calender material here.....
calender for next year would be good. SAUWA cars 2012.
Sounds good! If it materialises, I don't mind contributing (including Mickey's when the time comes). Just save a copy for me :pirate:
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
