Faq – General Maintenance
Guest RedLineGTR
Frequently Asked Questions & General Guides.
Electrical
-Headlight Gone Out (Left Side)
-Misfire Problem, Boost@4500-5500 RPM?
-Resetting the ECU?
-How to clean your AFM?
-HICAS Diagnostic & Codes?
-Aftermarket Tacho wiring diagram
-The Best Way To Disconnect a Car Battery?
-Dangerous power cut/jerks during WOT + high boost?
-Why does my speedo bounce and flick around?
Mechanical
Spark Plugs
Oxygen Sensors
Brakes
Clutch and Gearbox
Oil
Heating/Cooling
Servicing
Intake/Exhaust
Other
Interior
-Liquid Comin From Front Foot Wells?
-Door Window Tint Getting Scratched
Exterior
-Windscreen Rubber replacement
Misc
-Engine Firewall Blue Plate What's the Deal??
Maintenance Guides & Car Specific Problems/Issues.
R31
-RB30 specs, maintenance & modifications
R32
-Diff & Gearbox Oil What To Use
-R32 Gtst Timing Belt/Water Pump Part.No & Price
-R32 Oil Pressure Gauge Display
-Taking/Removing R32 Headlights?
-Where Is The Fuel Filter On A R32?
-Dodgy Climate Control Display?
-R32 Maintenance Parts and General Info
-ATTESSA Fluid Change + Bleed
-Handbrake Light Stays On !!
-Clear Indicators - GT-R and GTSt
-Rust Areas
-Steering Rack Boots - Repco Part number
-R32 GTR Low Oil Pressure / Oil Pressure Gauge Problems
R33
-Gearbox Oil Change
-Spark plug change
-Changing Parkers on an R33
-A Guide to Changing Your Oil & Oil filter In An R33!
-How to Change your own brake pads (Front + Rear)
-R33 Headlight Maintenance
-R33 Rear Seat - How To Remove?
-Blow Off Valves on R33 GTS-T??
-Gear box noises possible problems?
-Moisture in Headlight
-Steering Wheel Removal (Airbag)
-Water Pump Replacement RB25/R33 Whats Best?
-Clutch Adjustment Is It Possible?
-Common Rust Areas (R33 Specific)
-Adjusting Fan Belt Tightness!
-R33 Rear Brake Light Not Working?
-RB25DET stuttering/hesitation under load
R34
-R34 GT-T Spare Key Cutting?
-Removing Your R34 Shift Knob?
-R34 GT-T Spark Plugs, What to Use?
-R34 GT-T How Reset Your Stock Ecu?
-R34 Air Conditioner & Air Filter Maintenance!
GUYS USE THESE GUIDES AT YOUR OWN RISK. IF YOU HAVE A QUESTION ABOUT SOMETHING THAT YOU'RE NOT SURE OF PLEASE POST UP!! NO PERSON BUT YOURSELF TAKES RESPONSIBILITY FOR YOUR ACTIONS... and no person but you takes away the satisfaction of maintaining your Skyline by your own hand :P
https://www.sau.com.au/forums/topic/35442-faq-%E2%80%93-general-maintenance/
Guest
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
