Moved thread from the For Sale (Private Whole cars only) section to here as it was more appropriate since i ended up deciding to strip the car instead (http://www.skylinesa...-S-t340489.html).
Everything has basically been copied and pasted from the previous thread and is currently up-to-date. However, i have removed the Work wheels/nuts/hub rings from the listing as i have decided to keep them for the new car.
PM me if you want further information on any parts or i can be contacted on 0488 188 111.
Pictures can be found on my blog - http://vrsatyle.word...09/14/for-sale/
ENGINE:
RB30/25DET LONG MOTOR - $N/A
DUAL-CORE ALUMINIUM RADIATOR WITH 2X 12" THERMO FANS - $250
NISMO R32 GT-R IN-TANK FUEL PUMP (276L/HR) - $350
MALPASSI FUEL PRESSURE REGULATOR (RISING-RATE = 1:1) - $100
TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100
SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350
GREDDY OIL CATCH CAN - $80 SOLD
BRAND NEW APEXI GT SPEC RADIATOR CAP - $50
ENGINE MANAGEMENT:
APEXI POWER FC WITH HAND CONTROLLER (AP ENGINEERING/HCR32) - $1400
INDUCTION:
GARRETT GT3582BB (GT35R) 700HP DUAL BALL BEARING TURBO (0.82 A/R) - $1100 SOLD / PENDING PAYMENT
6BOOST RB25DET HIGH-MOUNT EXHAUST MANIFOLD (TUNED LENGTH) - $900
CUSTOM VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $300
DRIFT HIGH-FLOW POD AIR FILTER - $50
NISSAN Q45 THROTTLE BODY - $100 SOLD
NISSAN HCR32 AIRFLOW METER - $100
EXHAUST:
TIAL 44MM EXTERNAL WASTEGATE - $350 SOLD / PENDING PAYMENT
CUSTOM DUMP PIPE TO SUIT GT35 (HPC/CERAMIC COATED) - $200 SOLD / PENDING PAYMENT
CUSTOM FRONT PIPE - $80 SOLD / PENDING PAYMENT
HIGH-FLOW CAT - $100 SOLD
GARRETT GT35 TURBO BEANIE - $50 SOLD
TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" EXIT) - $400
DRIVETRAIN:
RB25DET GEARBOX - $1000 SOLD
CUSTOM 1-PIECE TAILSHAFT - $100 SOLD
NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED)/MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) - $550
USED EXEDY HD BUTTON CLUTCH (UNCUSHIONED)/USED RB25DET FLYWHEEL (TRAVELLED 8000KMS) - $200 SOLD
USED RB25DET OEM FLYWHEEL - $50
INTERIOR:
BRAND NEW APEXI AVC-R ELECTRONIC BOOST CONTROLLER (BLACK) - $600
APEXI TURBO TIMER - $50
APEXI S-AFC AND APEXI S-ITC - $150
RECARO SR2 RACING BUCKET SEATS (REPLICA) - $500 SOLD
EXTERIOR:
GENUINE NISSAN R34 CLEAR SIDE INDICATORS/WINKERS - $50
SUSPENSION:
TEIN HR-SERIES ADJUSTABLE COIL-OVER SUSPENSION - $600
R32 GT-R FRONT AND REAR STRUT BRACE - $100 SOLD
ROLLING SHELL WITH REGO UNTIL MAY 2011 (VEHICLE COMPLETELY STRIPPED. WILL SELL WITH FULL BODYKIT/BRAKES/DIFF/FACTORY R33 GTS-T RIMS/FACTORY SUSPENSION/FACTORY ECU): - $3000 NEGOTIABLE
Edited by GT32
  • Replies 63
*recomended seller*
gearbox is still going strong mate cheers again.
i think i might grab your injector setup off you in a couple of weeks if they havnt sold by then.
also what kit is on the rolling shell? are you willing to separate it?
- trent
*edit probs should have looked a the pix before asking, will you separate the kit?
Edited by TJR32GTS-T
Hey dude,
Not sure of the exact brand but people have told me it's an ECCS front and rear bar. I haven't seen alot of these kits around. Infact, i've only ever seen two R32's with this exact same kit (one in VIC and the other in QLD). I'm trying to sell the rolling shell with the bodykit intact at this point in time but if anything changes i'll let you know asap.
With my RB25 injector setup you might need to change to a forward-facing plenum and use an aftermarket RB20 top-feed fuel rail to make them fit as i'm not entirely sure that they will be a direct replacement on the standard fuel rail (can someone please confirm this?).
In theory, they are technically compatible as they're both high impedance and top-fed but making them fit into the standard fuel rail could be a different story. When i purchased them for my RB25DET head i already had a new plenum and fuel rail installed so we never got to test compatibility.
I'll do some research later and get back to you.
The rolling shell still comes with the complete interior minus the front seats.
I've had quite a few people ask me about this so just thought i'd clear it up now.
Couple of price updates as i really need these gone.
RB30/25DET LONG MOTOR (NEEDS NEW OIL PUMP AND CRANK COLLAR) - $1750 NEGOTIABLE
ROLLING SHELL WITH REGO UNTIL MAY 2011 (VEHICLE COMPLETELY STRIPPED. WILL SELL WITH FULL INTERIOR MINUS FRONT SEATS/FULL BODYKIT/BRAKES/FACTORY R33 GTS-T RIMS/FACTORY SUSPENSION/FACTORY ECU): - $2500 NEGOTIABLE
message pics of the shell to 0431 121 625, is that price including the interior body kit and so on ?
G'day mate. I'll take some new pics and mms to your mobile by tomorrow arvo and yes, that price includes everything that i mentioned in my last post still intact on the car. Engine loom is also still intact. You can see pics of the body from when the car was still running by going to my blog via the link in my signature or you can scroll up to my first post in this thread and click on the direct link to the pictures from there.
Edited by GT32
Mate, just tried to MMS the pics of the shell to your phone but on my side it keeps saying failed. Have you received them? If not, give me your email addy and i'll send them through there instead.
Details of the engine? Internals etc?
G'day mate,
Had a quite a few people asking about the motor so i'll just copy and paste the info from a previous enquirer...
"Not sure if you read my previous thread before i moved it over to here but the motor has a failed oil pump. Happened right after we installed the new clutch during idle when we were warming it up to give it a test drive. We noticed the oil pressure light had activated and we shut off the engine asap. Didn't have the car on for very long (~30secs) so i don't think it would've done any damage. I spoke to a few different workshops and they told me pretty much the same thing that the bottom end bearings will be fine as it happened during idle.
Motor has done roughly 8000kms. Max power it has made so far is 297rwkw @5800rpm/17.5psi during the run-in tune. We backed off at 5800rpm due to a faulty bleed tap boost controller not controlling the boost properly so i purchased an apexi avcr to replace the manual bleed tap controller and have the car retuned as the engine was pretty much run-in and due for its final tune. Obviously that never happened. We were hoping to make around 330rwkw on 20psi and rpm set to no higher than 6500rpm.
It was built by Ron Hutchins from Ronny's Performance Motors in Newtown, Geelong (parent company - Geelong Engine Replacement Services Pty Ltd). Engine was tuned by Raymond Ong from Auto Racing Technik (A.R.T.) in Heidelberg West.
I don't have the build receipts with me but can request the original receipts from Ronny's Performance Motors at anytime.
Engine specs are:
Series 1 RB30E short block with turbo oil feed and return separately drilled and tapped
Series 1 RB25DET cylinder head - reconditioned, ported and polished (VCT retained)
Standard series 1 RB25DET camshafts/valvetrain
Chemically cleaned, torque plate bored and honed block
Block 20-thou overbore
Compression 8:1
Wiseco forged pistons
Chromoly piston rings
Crack-tested RB30ET rods
Machined RB30ET crankshaft
Bottom end completely balanced
ARP head studs, main studs and rod bolts
Genuine nissan engine bearings throughout
Genuine nissan RB30ET oil pump
Genuine nissan RB30ET water pump
To have it back up and running requires a new oil pump (i recommend an RB25DET oil pump) plus a new wide-angle crank collar (from proengines.com.au) as i suspect that the pump failed due to wear and tear of the narrow factory RB30 crank collar hence not driving the pump.
It comes with the PWS/air con pumps and alternator plus coil packs and ignitor still intact."
Edited by GT32
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
