  • Replies 63
Just a small update to let everybody know exactly what I still have left over for sale. I will also be taking photos of all the available parts in the coming days and uploading them here. Any questions just PM me or call / txt 0488188111.
RB30/25DET BUILT LONG MOTOR (NEEDS NEW OIL PUMP AND CRANK COLLAR) - $1500 NEGOTIABLE
MALPASSI FUEL PRESSURE REGULATOR (RISING-RATE = 1:1) - $100 SOLD / PENDING PAYMENT
TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100
SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350
CUSTOM-MADE VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $300
TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" CANNON EXIT) - $350
NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED) AND FRESHLY MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) INTERCHANGEABLE BETWEEN HCR32/ECR33 S1 - $450
USED RB25DET OEM FLYWHEEL - $50
USED NISSAN S15/R34 FACTORY YELLOW SIDE INDICATORS/WINKERS (WITH LOOM AND PLUG) - $30
BRAND NEW URAS STYLE REAR BAR AND SIDE SKIRTS FOR NISSAN S15 (UNFITTED/UNPAINTED, STILL IN GEL COATING) - $300
Edited by GT32
  On 02/05/2011 at 12:44 PM, wpnsx said:
Could you do the OEM flywheel posted to 3096 for $60?
Also do you have the flywheel bolts?
Where area is 3096? Maybe I can come and drop off to you.
I have the complete RB25DET flywheel bolts as well. Was going to include them for the buyer of my other Exedy clutch and flywheel combo that I have for sale but if you're after them I'll do them for $20.
Edited by GT32
  On 04/05/2011 at 10:05 PM, Beacher1B0 said:
Does the HCR have H1 Headlamp Bulbs? Im looking for the Bulb Holders.
R u willing to seperate them from the Headlamps?
R u willing to ship em overseas?
Don't have those sorry.
Added to listing:
BRAND NEW VERTEX STYLE REAR BAR AND SIDE SKIRTS FOR NISSAN S15 (UNFITTED/UNPAINTED) - $300
Also just finished taking photos of everything that I've got for sale. Will post them up in about half an hour.
Another price drop. I need these gone!!
TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100 FREE WITH PURCHASE OF INJECTORS
SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350 INCLUDING RB25 TWIN-ENTRY FUEL RAIL
NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED) AND FRESHLY MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) INTERCHANGEABLE BETWEEN HCR32/ECR33 S1 - $450 $400
Prices are marginally negotiable. PM for more info.
NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED) AND FRESHLY MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) INTERCHANGEABLE BETWEEN HCR32/ECR33 S1 - $450 $400 SOLD
Edited by GT32
Price drop again!
CUSTOM-MADE VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $300 $250 NEGOTIABLE
TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" CANNON EXIT) - $350 $300 NEGOTIABLE
Someone buy these! lol.
TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100 FREE WITH PURCHASE OF INJECTORS SOLD
SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350 INCLUDING RB25 TWIN-ENTRY FUEL RAIL SOLD
Edited by GT32
  • 3 weeks later...
  • 1 month later...
  • 7 months later...
Hey guys, just wanted to reopen this thread as I still have some parts leftover that I need gone! Everything stripped/leftover from my old HCR32. Located in Geelong, VIC
Still for sale:
USED RB30/25DET LONG MOTOR (NEEDS NEW OIL PUMP AND CRANK COLLAR) - $1500 NEGOTIABLE $1000 SLIGHTLY NEGOTIABLE / PM FOR MORE INFO
USED CUSTOM VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $250 $100
USED TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" EXIT) - $300 $150
USED NISMO BNR32 GT-R IN-TANK FUEL PUMP 276L/HR (TRAVELLED ~6000KMS) - $300
Edited by GT32
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
