  • Replies 63
Just a small update to let everybody know exactly what I still have left over for sale. I will also be taking photos of all the available parts in the coming days and uploading them here. Any questions just PM me or call / txt 0488188111.
RB30/25DET BUILT LONG MOTOR (NEEDS NEW OIL PUMP AND CRANK COLLAR) - $1500 NEGOTIABLE
MALPASSI FUEL PRESSURE REGULATOR (RISING-RATE = 1:1) - $100 SOLD / PENDING PAYMENT
TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100
SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350
CUSTOM-MADE VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $300
TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" CANNON EXIT) - $350
NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED) AND FRESHLY MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) INTERCHANGEABLE BETWEEN HCR32/ECR33 S1 - $450
USED RB25DET OEM FLYWHEEL - $50
USED NISSAN S15/R34 FACTORY YELLOW SIDE INDICATORS/WINKERS (WITH LOOM AND PLUG) - $30
BRAND NEW URAS STYLE REAR BAR AND SIDE SKIRTS FOR NISSAN S15 (UNFITTED/UNPAINTED, STILL IN GEL COATING) - $300
Edited by GT32
Could you do the OEM flywheel posted to 3096 for $60?
Also do you have the flywheel bolts?
Where area is 3096? Maybe I can come and drop off to you.
I have the complete RB25DET flywheel bolts as well. Was going to include them for the buyer of my other Exedy clutch and flywheel combo that I have for sale but if you're after them I'll do them for $20.
Edited by GT32
Does the HCR have H1 Headlamp Bulbs? Im looking for the Bulb Holders.
R u willing to seperate them from the Headlamps?
R u willing to ship em overseas?
Don't have those sorry.
Added to listing:
BRAND NEW VERTEX STYLE REAR BAR AND SIDE SKIRTS FOR NISSAN S15 (UNFITTED/UNPAINTED) - $300
Also just finished taking photos of everything that I've got for sale. Will post them up in about half an hour.
Another price drop. I need these gone!!
TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100 FREE WITH PURCHASE OF INJECTORS
SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350 INCLUDING RB25 TWIN-ENTRY FUEL RAIL
NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED) AND FRESHLY MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) INTERCHANGEABLE BETWEEN HCR32/ECR33 S1 - $450 $400
Prices are marginally negotiable. PM for more info.
NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED) AND FRESHLY MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) INTERCHANGEABLE BETWEEN HCR32/ECR33 S1 - $450 $400 SOLD
Edited by GT32
Price drop again!
CUSTOM-MADE VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $300 $250 NEGOTIABLE
TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" CANNON EXIT) - $350 $300 NEGOTIABLE
Someone buy these! lol.
TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100 FREE WITH PURCHASE OF INJECTORS SOLD
SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350 INCLUDING RB25 TWIN-ENTRY FUEL RAIL SOLD
Edited by GT32
  • 3 weeks later...
  • 1 month later...
  • 7 months later...
Hey guys, just wanted to reopen this thread as I still have some parts leftover that I need gone! Everything stripped/leftover from my old HCR32. Located in Geelong, VIC
Still for sale:
USED RB30/25DET LONG MOTOR (NEEDS NEW OIL PUMP AND CRANK COLLAR) - $1500 NEGOTIABLE $1000 SLIGHTLY NEGOTIABLE / PM FOR MORE INFO
USED CUSTOM VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $250 $100
USED TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" EXIT) - $300 $150
USED NISMO BNR32 GT-R IN-TANK FUEL PUMP 276L/HR (TRAVELLED ~6000KMS) - $300
Edited by GT32
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
