Hey guys,
after driving my stagea normally what happens is i put my car in neutral and i pull my handbrake up, i then hear a click and then i turn the ignition off and the turbo timer kicks in.
the other day i went to my car and it was beeping .. 3 beeps and then a pause and then two beeps
i then started my car and it stopped.
i turned my car off and then the beeping continued, i then went for a drive and was at the lights so i decided i would check to see if the turbo timer was still working, so i pulled my handbrake up, heard the click and then i turned it off, and no turbo timer....
Normally what happens is when i dont turn my car off with the turbo timer i let it cool down and then i hear another click and i know that the turbo timer wont turn on.
Now i drive for a few seconds and then it clicks off, while i am driving, it doesnt normally do that.....
so i ripped my dash apart and finally found what is making those clicks...
A-731E
s/n 51201118
halfway through the putting the dash back into the car i decided to test it to see if the car would start and just to make sure i didnt knock any wires out of place. Turned the car on and then off and the turbo timer kicked in.
but yeah. any help would be greatly appreciated , i would like to fix this issue and i dont really have the money to go get another one put in.
Thanks
https://www.sau.com.au/forums/topic/354461-stock-turbo-timer/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
