I doubt you'll get over 400rwkw with a 0.82 rear on pump. I would think that around 350rwkw would be maximum on pump with a 0.82rear.
As for intercoolers - The most thermally efficient cores I've seen are from process west. The plazmaman ones are close but process west are definately the best.
There have been a few people that have cracked 400rwkw with the 82 rear. check out this thread. http://www.skylinesaustralia.com/forums/topic/251820-got-over-400kw-atw/
My setup is aimed at 400rwkw and im running the 82 rear.
So Guys, would a T4 1.00 split rear housing be a good option?
just remember someone saying the split exhaust housing could restrict flow? is this true?
I dont think theres a need to go to a T4. you always want to match turbos to your power goal and nothing bigger. Whats the cars aim and power goals?
Id have to agree with you about the doubt. Ive been trying for a good year to crack the 400kw on the .82 rear however most for the time is just saving up to buy the parts. All i need is new intercooler and possibly new valve springs. Fingers crossed =]
There have been a few people that have cracked 400rwkw with the 82 rear. check out this thread. http://www.skylinesa...over-400kw-atw/
Whats your current setup atm Jack88? spec list?
Stock cams probly an issue.........
Looking at dragging the car. it is a S14a 200sx dry sump etc just brought a borg warner 9180 ...
So im looking at selling this turbo if you know anyone :P
Spool rods
ACL forgies
272 ,9mm lift cams
ferrera valve springs
1mm oversize exhaust valves
ported head
6 boost mani
greddy plenum
ross ballancer
and everything else you do to make an engine like this reliable
It made 220rwkw and 400nm of tourqe at 5000 rpm running just the 7psi wastegate spring (no boost controller) starts making boost at 2000 rpm. This was for run in, The tune is pritty rich too so if i wanted it it would probly be able to get another 20kw or so out of it and still be a nice and safe tune. The thing pulls like a train even when only reving it to 4500rpm (this is the limiter for run in) so im not even using the turbo in its efficiency range yet.
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
