Last time the mechanic tried to change my gearbox oil they damaged the head of the drain plug severly by using the incorrect tool ( A half inch square socket drive ).
I bought the correct 13mm square drive drain plug tool that i thought might be able to get it out cause it still fitted in the hole tightly. I tried to un do it with both my hands and my girlfriends legs on a power bar couldnt even budge it we had that much force on the bar that the knuckle was flexing and because weve put so much force on it it has further damaged the drain plug.
I dont know what to do, im running out of options.
The thing that pisses me off is you would think that a reputable mechanic shop that services skylines all the time would have the correct drain plug tool or if they new they couldnt get it undone they wouldnt totally #@%& it.
Im just really pissed off, Can anybody offer any solutions. Its got to come out.
https://www.sau.com.au/forums/topic/354533-gearbox-drain-plug-damaged/
I had to put a sleeve if pipe over my breaker bar to get the transfer case filler bolts out and even still it was hard work
I thought I was gonna break the bar or pull the gearbox out
The steel plugs often bind in the aluminum housing of the box due to electrolysis. If you can give the plug a sharp hit with a hammer, this will often free it. Alternatively, a can of freeze spray (CRC make it) will shrink the plug & break the bond.
Yep i had that thought this morning as my last resort, went to bunnings bought a steel square section bar about 1200 long and i got it out, it was still bloody hard but its out and im smileing yay
  • 4 months later...
Seems I left the best till last, done the final drive oil changes except the transfer case a while back, fairly straight forward getting bungs undone. Last weekend put the stag on stands & tried loosening the transfer case filler plug, I've now got a small pile of broken tools & a sore arm and the plug is still in there. Good news is the square hole of the plug is still ok, shame it's only a 10mm square.
I broke an SK 1/2" to 3/8" adaptor socket then I welded an old 3/8" rachet solid - broke the square drive off & bent the handle. Next up cut & filed a high tensile bolt to a 10mm square as a key, quite good because it capped the plug & I could give plenty of taps with a hammer to help loosen it, all strength maxxed out pulling on a ring spanner - still wouldn't budge. My son climbed under the car from the other side pushed real hard with his boot on the spanner - spanner bent, plug still stuck. Not that keen on waving oxy/fuel torch under there.
Round 2 coming up another time when I have it up on stands.
Last time I had a bastard bolt like this I wrapped a nylon strap round the spanner and hooked the other end to my engine crane. Had the wifey crank the crane until it let go. Almost lifted the front of the car on the spanner!
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I dried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4     I did the other 5 in less time than I fluffed around with the first one. I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the casing. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I overcome one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
    • Even back in the day, some importers were renowned for bringing in crashed cars, giving them a quick touch up + respray and making them look mint
    • No new updates from the op after covid, hopefully everything is ok...
