just throwing this out there, maybe putting my car up for sale
1992 R32 Gts-t Skyline
Black with blue pearl
230000km's
Info:
R34 GT-T turbo
Trust Type S adjustable coilovers
Trust Type M front mount intercooler kit
Vertex copy body kit
Split fire coilpacks
3" turbo back exhaust 1 muffler - twin 3" tip
Aftermarket adjustable front camber arms and adjustable tie rods and ends
other various info:
timing belt kit and water pump replaced just before christmas last year
i replaced all of the coolant hoses and clamps that run under the plenum with new geniune items just over a year ago
i bought the car in december 2007 and i service it with Motul 8100 every 5000km's
aircon has shit itself - i think the compressor needs replacing
it just needs some bigger injectors and a Z32 AFM and it will make 200rwkw with another tune.
the car is currently tuned with a Power FC with 170rwkw - power FC not included unless you're willing to pay extra it will be replaced with a standad ecu (still runs fine with the turbo)
car currently has Work XD9's 17 x 8.5 and 17 x 9.5 i bought brand new late last year - not included unless willing to pay extra ( i have some R32 GTR wheels i can put on it otherwise)
$11000 ono rego until May 2011
or $13500 with the power FC and work wheels included
this car has been my baby and i've spent a lot of money on it in the time i've had it
After a wash with the old drifteks (they are sold fyi) it had when i bought it:
http://img29.imagesh...i/69254257.png/
The night i got it:
http://img11.imagesh...i/72382167.png/
just after i had the XD9's put on:
http://img713.images...2302708822.jpg/
dyno print out:
http://img198.images...us/i/dynot.png/
personalised plates do not come with the car under any cirumstances
Located on the northside of brissy around chermside
0413377833 or PM
Edited by mystery_kid
https://www.sau.com.au/forums/topic/354544-eoi-r32-gts-t-skyline/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
