Hey guys, i'm at a cross roads, hoping your input may sway me.
i have the opportunity to buy a crate motor (long motor) (cams, springs, pistons ect) ready for turbo/s
and a diff (tomei) to put down such power in a decent fashion.
or leave my car stock, and sell then upgrade.
keep the v35 luxury, or step it up a notch to bullshit power?
the mods will cost about $18,000 once finished
i know its my decision to make and my money, but is it worth it in your eyes?
or pointless.
bring up some valid points
its an 03 6mt v35 coupe.
should i save the dollars and buy a 36/370?
or something else
or have a 500Hp+ v35?
will the dramas start once i get my motor built?
https://www.sau.com.au/forums/topic/354576-to-do-or-not-too/
Hmm... Over-invest on an import or enjoy Fish Hut chips on the beach instead? A no-brainer for me (Fish Hut chips @ Burleigh are the best). This is an emotional question which only you can answer. Personally, I reckon that with some minor touches the current models are King - why mess too much with perfection when there is a speed limit on roads and QLD police seem to be everywhere? Put your money onto maintaining vehicle currency is my recommendation - go the 37.
If you intend to keep the V35 go nuts. But if you want to sell it one day you will just be throwing away your cash. Do up your car because you enjoy it. Mods don't make a lick of difference when you try to sell your car later.
^ I also agree with the above comment.
Plus, you will be spending heaps more to maintain that modified-engine components. When it's time to sell it, you will lose the lot of money.
Good luck.
put a s/charger in, but keep all the stock components in ur shed ( don't sell these off and try to recoup some money)
When it comes time to sell, return the car to stock and sell the aftermarket bits off
(no one believes ads that say "twin turbo 500hp V35 skyline with Dyno Charts to prove...meticulously maintained, only driven weekends, never driven on high boost, mature driver...bla bla...bs bs and more bs)
Depends what your goals are performance wise.
I can get up to 400hp comfortably with my set up and not be on the edge of breaking anything. I have a forged engine, Vortech s/c @ 8.5psi currently making 350hp. Why would there be any dramas after your motor gets built? If everything is done right then you will have no issues, don't cut corners and you will be fine. Make sure you get a reputable tuner as well.
Depending how much the crate motor costs, work out how much it will cost you to build your engine with forged internals and cams. Do lots of research.
I daily my v35 and it behaves as normal for daily driving duties, still has all the comforts, but have the potential for more go when I want it to.
Costs aspect, you will almost always lose money on mods, if you're concerned about that then don't mod your car.
Thanks for all the helpful input guys!
money wise, its not a major worry... modifying costs. if you dont understand that, you cant be a true enthusiast.
Im thinking along the lines of investing into a v36 just for the added features.
then if its still not wild enough, i always have a chance at modifying that.
ill keep the V for a while. then upgrade.
for the moment, its more awesome looks for this V. might as well make it look awesome in the meantime.
thanks again guys!
your input helped push me in the direction i was thinking anyways.
I still have my eyes on the complete setup, maybe if it come in cheaper... i will.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
