r33 parts
driver door & mirror, glass $100 silver
stock intercooler $20
washer bottle $15
overflow bottle $15
bonnet verticle lock support $10
inlet manifold with sensors $ 30
subframe with all arms $100
stock front pipe with cat $30
steering colloum with ignition barrel with door locks and 3 keys$70
boomex sides maroon genuine $ 60
type m rear pods maroon $80
cluster $ 50
stock fuel pump $15
s2 drivers side window switch $30
starter motor $50
s1 front seats drivers rail needs work$50 pair
front cross member $70
drive shafts $60 pair
r32 parts
turbo no actuator $100
center dash vent $60 mint
2 door tail lights $50 pair
after market front shocks look stock height $50
gtr caster rods with white line bushes $50 pair
4 door front seats $50pair
lca' $70 pair
stock fuel pump $15
diff has been shimmed with new oil used for 3 months on street $ 120
power steering pump hicas $50
alternator with loom $50
starter motor $50
a/c compressor has been freshly oiled $100
air con condensor with lines and fan $80
r32 gtr genuine front bar with lip and mesh ,needs small repair easy $350
r32 gtr fuel pump with sender $80
isoto steering wheel red $50
autometer lgf gauge 30 psi & cup $30
blitz timer $15
25mm bolt on spacers $100 or swap for 15mm or 20mm nissan thread
s15 front crossmember $50
r34 a/c compressor $150
r34 drivers door with glass red $200
located in adelaide athol pk text 0422030855 can mms any pics...
swaps for 32 gtr drivers seat ,s13/32 adjustable camber arms,toe arms,r33 adjustable rear camber arms
Edited by hcR324door
https://www.sau.com.au/forums/topic/354581-shed-clean-up/
