It is time to part with my poor Suzuki Carry Van.
Story: Blew head gasket and cracked the head - bought brand new head and had the motor reconditioned so it was basically brand new again. It then got hit by a taxi who didn't mirror check when changing lanes which accounts for the minor front end damage, it then got flooded during the floods, that's when I called it quits *sigh*. Gearbox is good, and the engine is good except now needs to be pulled down, cleaned, and put back together because of the water inundation. It's got a Haymen Reece towbar. All the windows are tinted and in good condition (rear left is missing). Passenger side door has slight dent. Interior is all there, just needs a proper wash.
Vehicle is currently Unregistered and on the WOVR.
I'm looking for $500 for the whole thing "as is", or, parts I will sell seperately are priced as follows:
- windows: $50 each (I have had to replace 5 of the windows while I owned it, they retail new from between $200-$300 each, so this is a bargin!)
- Haymen Reece Towbar: $150 (bought new & had installed for $350 all up)
- Lights: $10-$50
- Interior bits: $10-$50
Don't want to sell any of the rolling gear as I need to move it eventually if nobody buys it.
I am open to offers and trades for other car parts or misc stuff such as computer gear, home entertainment etc, just send me a PM worst I can say is sorry not interested.
I have recipts for all the engine and other vehicle work done by UltraTune at Sandgate.
Located in St.Lucia, Brisbane. Call Michael on 0413504084, thanks.
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/354589-wrecking-00-suzuki-carry-van/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
