Hey does anyone have a racing bucket seat? I'm thinking it would be cool to make a racing simulator. I have a spare racing wheel and some older computer equipment. I can weld up a frame but just need a decent racing seat.
How cool would that be for the clubhouse? Say a best laptime leader board in the clubhouse?
There are a few key items missing from the list Stevo, namely:
1. Stripper pole
2. Dyno
3. Hoists
NO we are missinzz the womenzzzzz GET ME THE WOMENZZZ!! :P, I wouldnt mind helping u pezhead mind u No experience with welding but i do some labour LOL AFTER WORK HOURS though :P
Sid
+1
Part 1 requires strippers though... not sure i wanna see any of the guys strip
I can donate a wig to go with that hahaha
I've got a nice compact Computer desk with hutch in really good condition, let me know if its wanted.
I have a stereo (all in one tuner/CD player/equaliser etc) if you want it. Nothing flash but works fine. If you're interested N1GTR, PM me and I'll send you a pic.
Also, if you need any computer parts, switches, cabling etc, gimme a yell.
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
