* Good News:- We now have a Clubhouse!
* Bad News:- It ain't in Canberra
Addy thanks to Todd and Yumi of JapLink is, 175 Parramatta Rd Haberfield
We are looking for some furniture to kit it out, so have a squizz at Steve-0's thread and comment!
Q. Can a Canberran stay overnight if pooped and short of cash?
A. Only if Shell is staying over too - 'cause she'll have a key (and only if you don't snore - 'cause Shell will bash you over the head if you snore)
Q. What will it be used for?
A. Meetings, AGM, viewing WRC/F1/Races
https://www.sau.com.au/forums/topic/354631-saunsw-clubhouse/
  • Replies 45
Good Questions ^ ^ ^
* We can use the JapLink site 24/7 as we'll be occupying Suite#2 upstairs.
* If the JapLink is being used (daytime Mon-Sat), we'd need to park around the corner in a quiet residential street called Chandos St
* Outside of bus. hrs, we are able to use the yard and with the keys (that an Exec will have), it is secured parking.
* The driveway just needs to be taken at an angle and a low lip car will have no problem. There will be no cover. It's open.
* However, if you've parked around the corner in Chandos St, always go back onto Parramatta Rd. The back streets have deadly speed humps.
Hang on, so let me get this straight.......we can stay there but we have to spend the night with Shell??......hmmmmm :w00t:
    • My rotisserie is due to be delivered next week and I need to get my R32 mounted on to it. I know how to mount it on the actual rotisserie but those of you that have, did you add any additional bracing to the chassis? I was planning on welding some 1x1 box section across the top of the seatbelt buckles, across the back seats and then down to the front footwells (and possible across from there also? I've also put the behind dash bar back in to give a bit more strength. Its mostly going to be the floor and sills being cut out with a little on the rear quarters
    • apparently people are still having trouble with this as well
    • Only problem with that is it's obvious to the police, but same same with the aes valve. Most people get the valve precat so it's harder to see when looking under the car from the rear.
    • It's been a looooooong while since I did this, but... No, from memory there's a feed ring around the inside of the squirter. Otherwise,  they would have to be too precise when machining the threads in the block, and the banjo bolts themselves.
