Clutch booster is stuffed (hissing under pedal when de/pressing clutch) and i can't change it until the weekend so i was wondering if anyone was able to tell me what i cap off to stop the air escaping as a quick fix until the weekend and will the clutch be way too hard to drive?
Edited by topher_
https://www.sau.com.au/forums/topic/354647-clutch-booster/
The should be a single pipe come from the booster to feed it vacuum, so you should follow that and plug the end.
re pedal pressure, its probably similar to what its like when the engine is off.
https://www.sau.com.au/forums/topic/354647-clutch-booster/#findComment-5682768
