I recently had to take my car in due to faulty solenoids (solenoid A error), turned out that there had been water in the tranny and needed a rebuilt so what needed to be replaced was replaced. However now with the new tranny / solenoids the car will still jump into limp mode. Car will start normal but as soon as it gets into 2nd/3rd it'll jump into limp mode. The error can be erased with the handheld device (while driving and in limp mode) but once you stop and take off again it'll jump back into limp mode each time.
- Trans has been replaced.
- soleniods been replaced.
- Wiring looks OK.
- Trying to see if another earth will help
- Could it be an issue related to the tranny ECU?
Does anyone have any ideas of what could now be the issue?
Looking around on the forums there seems to be no sure answer and yes... manaul conversion is a 'last resort'
At one stage I had a dicky earth clamp on the battery, some bumps would move it around, there would be a big lurch and the auto would drop in to limp mode temporarily.
So yes, dodgy earth could be the culprit.
What error code is it throwing up?
Solenoid A before and after, its odd that the car will go in limp mode everytime it gets into 2nd from standstill after the codes get whiped while driving.
Before I had the trans rebuilt the limp mode was 'normal' (for what it is) but now it seems to always just come up right away. However the car drives perfectly fine when not in limp mode
Take it back to the place that rebuilt the transmission, you should have gotten some sort of warranty with it. How long ago was it overhauled?
The auto control unit is part of the ECU, not a separate unit like earlier models.
And if it's throwing the same error before and after the rebuild, that makes me think that whatever they did DIDN'T fix the issue.. I hope you're not paying for them to learn..
Edited by bubba
Haven't paid them yet!
They say rebuild is fine, auto electrician said the wiring seems ok, they've tested the voltage at the solenoids (have been replaced) which seems to be all ok and the earthing seems to be ok too. They seem to be out of ideas of what it could be so I don't really know what my options are. Send my ECU's out to get them checked or even try sending it to a specialist to have a look over?
When the errors are cleared the car drives fine so something for some reason is causing the error to pop up and jump into limp mode wether its faulty soleniods or something else lurking around.
Don't really know what direction to take this in or what my options are?
Edited by noexec
OK here's a little anecdote that might help shed a little light..
When I was playing around with NIStune'd ECU's in my car I was doing a lot of swapping of ECU's. If I just pulled the ECU out without bleeding any residual current in the system (i.e. not pushing the brake pedal after disconnecting the battery), it would throw up HEAPS of A/T errors including a bevy of solenoids and other stuff but nothing was actually broken. It was just the control module flipping out because I didn't discharge the residual current in the system.
The point I'm trying to make is that it *could* be an intermittent earthing or wiring problem somewhere and it sounds like the problem was there before the rebuild and the box probably didn't need new solenoids etc.
Try reset the ECU, if that doesn't work then the auto-sparky needs to be present when the problem is replicated. If it works for a while and randomly drops in to limp mode I highly doubt the TCM (inside the ECU) is the culprit, sounds more like a wiring/connector issue.
Edited by bubba
Update (have been too lazy to post), issue has been fixed. Although I told the mechanic to reset the ECU (he also said he had) I guess he mustn't have because the codes cleared up after a while of test driving it around. All good now thumbsup.gif
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
