Hey guys, thought I'd show you our R34 which we will be debuting at the Sydney Powercruise in a couple of weeks. It's been a while in the making so finding the time to finish it has been a task amongst all of our customers cars!
It features a BC 2.8L stroker engine, Precision 7175 turbo and Haltech Platinum Pro ECU. The drivability of this thing is awesome, with the gates cracking at about 4600rpm in 19psi. Although it has Bosch 2000cc injectors in it, we hadn't upgraded the rear section of the fuel system but will have it finished this week. That's the reason why you will notice a lean graph, so we capped the revs at 5500rpm. Even so, as you will see it's still a quick car on 323kW, we think another 25psi will help it nicely :)
  • 1 month later...
what hp was it tuned at powercruise.. took some video footage it was mental quick
  • 1 month later...
At Powercruise the car was on 35 psi and 600 kw at all 4,its since been retuned on 45 psi for 703 kw at all 4.Oh yeah its got some alright.Oh almost forgot the Hollinger goes in this week all being well.Keep your eyes out for the white 32 GTR coming out next.3 litre ,Borgwarner S480,nos and eventually a powerglide ,MMMMMMMMM.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
