Hey guys,
I'm looking at buyer an R34 GTR at the moment.
The owner has blowned the engine before by putting more than 25psi boost on the standard engine and turbo, resulting in snapping the crankshaft (does that sound right?) . What usually happens when you snap the crankshaft? what other parts does it damage?
Anyways, the engine has been rebuilt using : 'bottom end are: standard nissan crank shaft, scat h beam conrods and je forged pistons with rings'
now i am planning to mod it to about 300-350kw. Will the standard crank shaft be strong enough? and i tried googling scat H-beams and i cant find infomation about it...so has anyone had any experience or heard anything about these rods?
the engine was also rebuilt was done in a small town by a local mechanic. so i am skeptical about the build. The mechanic has basically told me he has rebuilt the engine and the car is just running factory power, becuase the owner doesnt know much about cars.
the price is really good, so im tempted to buy it
let me know what you guys think
thanks guys :thumbsup:
https://www.sau.com.au/forums/topic/354666-gtr-r34-rebuilt-parts/
im quite sure that there must have been other propblems, ive seen people run 700+ horses on the standard crank. (nothing modded or changed either)
just make sure that the block is in good condition and same goes for the head. which is a bit of a hard thing to check. but i doubt they would rebuild it with a crap block/head anyways
Yeh im hoping the block and head were fine after the engine went bang. Im not sure how to check that but i will bring it to a mechanic and get the whole car checked out before i buy it.
Has anyone heard of Scat H-beam conrods? i want to know if they are any good. are they cheap?
cheers
http://www.scatenterprises.com/
check them out, and i really doubt that any aftermarket forged items would be crap... just saying :)
main thing to check i guess would be smoke from any oil problems, valve seals, scrapes inside of block etc.
highly doubt they wouldnt get it re honed or bored/fixed while they rebuilt it.
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
