About 4 years ago bought an Aussie R32 GTR with a damaged engine. Apparently the idler puller had let get (when it was idling, cooling down after a dyno run) and did major damage to the head when the timing went out.
I replaced the motor with a fresh R33 GTR motor (I still have the original motor plus a spare block, head and gearbox, other bits like dump pipes and bigger turbos). New clutch, new brakes.
I have only driven about 4,000km since the new engine.
Overall mechanically good.Interior very tidy. Minor cosmetic body problems and a few spots of rust near windscreen that haven't changed in 4 years. Pretty much original condition except for bigger intercooler and exhaust.Drives well. 246,000 kms.
I no longer have much opportunity to drive it and it is a car that would do better being used than stored.
I was hoping it may be an appreciating asset but I am not sure if I should sell it or store it for 10 yrs.
I am not sure what it would be worth as there are a couple of these, possibly better condition, chasing $78k and $60k.
Any thoughts?
Frank
https://www.sau.com.au/forums/topic/354711-aussie-delivered-r32-gtr/
Its sure to appreciate but how long it takes is the question. I reckon you might be waiting 20yrs before its valuable..But that give you a lot of time to gather up parts for a ground up rebuild to original condition..Just think what a fully restored muscle cars goes for these days, they're not cheap. GTRs may be plentiful now but 1 by 1 they are getting over modded and smashed,crashed bent twisted and stuffed. I guess it depends what its costing you to store it..If its not costing and you dont need the cash let it sit..It is a solid investment and you wont regret it..
Edited by Arthur T3
Not to be a knob, but surely for it to be worth something, it has to be totally original? Including engine...
And its got 246k kms (Yes, I know imports are wound back etc)
It does look really good though.
Edited by Ten Four
Hey Ten Four what wing are you running in that pic
It looks like a standard wing.
Here are some pics of mine that I took last Sunday......... The garage was owned by the original owner when the car was new.
Bob.
  • Like 1
Frank, do you have books for the car? If you were to sell it i would rebuild the standard motor and get it back as close to standard as possible.
The vehicles you have seen going for big dollars are mint units like Bobs maroon one above (with 50kms on it).
These cars will shoot up in value in another 10 years, where they go from there is anyones guess. If the cash is not a problem Id just remove the fluids, stick it up on stands and leave it be.
Keep and use the original block whatever you do.
Even if you mod it just make sure it looks standard. Inside no one could tell if its an HKS 2.8 stroker or a standard 2.6:)
I'm all for modding but keeping standard appearance (aside from suspension, exhaust and wheels). Except for Bobs, which still looks like he took delivery from Nissan this morning so probably best let his car become the museum piece in the future!
Edited by gtr fan
Bob.
I recognise that workshop. Although since moving to sydney in 1985 I don't recall ever seeing a car in that brilliant showcase on the front! Is that workshop still operational?
Wanted to get it up and running at the time.
Have original block etc.
Probably enough bits for two engines but not the enthusiasm.
Frank
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
