So this is what i got, prices are slightly negotiable but dont push your luck.. it's all top quality gear.
1.Rb25det, Lume & Gearbox Long motor and box, 63 xxxkm, very fresh motor, got it out of a half cut imported by Option 1 Garage. Everything but AFM $3500
* no pic - its a stock engine and gearbox *
2.Trust TD06 25g, Trust 50mm Wastegate, Trust Stainless Hi Mount Manifold - Comes with braided turbo oil line, Trust heat shield, polished front pipe, Dump and front pipe, Z32 AFM. Manifold has just been reinforced by Nathan at Fabulous Fabrications. $3200
Nathans handy work ^^
3.OS Giken Twin Plate Clutch - bought from JDM Garage and rebuilt by NPC $1050
* no pics, but can get one if you really want *
4.Polished GReddy Intake Plenum - Brand new never fitted to an engine. Comes with everythng from the factory including fittings, throttle body adaptor, silicon, hoses etc. $1100
Everything located in Brisbane, prefer pickup but will freight anywhere at your expense, but only if you are straight up and easy to deal with.
Begin throwing money at me.
Edited by Above_BAR
https://www.sau.com.au/forums/topic/354722-best-rb25-setup-money-can-buy/
Hey budy, do you still have the turbo set up?
Does the front pipe include the external waste gate connection pipe or is it a screamer set up?
Do you have any pics of the turbo and did you have it running on this engine set up or did you just buy it all and never end up using it?
have just taken a deposit on the turbo setup.
if it falls through i will let you know mate.
but to answer your questions, yes the front pipe has a flange on it for the wastegate, but i was intending on using a screamer. i have never used this gear, it is still in the box it was delivered to me in. None of it is new, but in very good condition.
  • 3 weeks later...
  • 3 weeks later...
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
