So this is what i got, prices are slightly negotiable but dont push your luck.. it's all top quality gear.
1.Rb25det, Lume & Gearbox Long motor and box, 63 xxxkm, very fresh motor, got it out of a half cut imported by Option 1 Garage. Everything but AFM $3500
* no pic - its a stock engine and gearbox *
2.Trust TD06 25g, Trust 50mm Wastegate, Trust Stainless Hi Mount Manifold - Comes with braided turbo oil line, Trust heat shield, polished front pipe, Dump and front pipe, Z32 AFM. Manifold has just been reinforced by Nathan at Fabulous Fabrications. $3200
Nathans handy work ^^
3.OS Giken Twin Plate Clutch - bought from JDM Garage and rebuilt by NPC $1050
* no pics, but can get one if you really want *
4.Polished GReddy Intake Plenum - Brand new never fitted to an engine. Comes with everythng from the factory including fittings, throttle body adaptor, silicon, hoses etc. $1100
Everything located in Brisbane, prefer pickup but will freight anywhere at your expense, but only if you are straight up and easy to deal with.
Begin throwing money at me.
Edited by Above_BAR
https://www.sau.com.au/forums/topic/354722-best-rb25-setup-money-can-buy/
Hey budy, do you still have the turbo set up?
Does the front pipe include the external waste gate connection pipe or is it a screamer set up?
Do you have any pics of the turbo and did you have it running on this engine set up or did you just buy it all and never end up using it?
have just taken a deposit on the turbo setup.
if it falls through i will let you know mate.
but to answer your questions, yes the front pipe has a flange on it for the wastegate, but i was intending on using a screamer. i have never used this gear, it is still in the box it was delivered to me in. None of it is new, but in very good condition.
  • 3 weeks later...
  • 3 weeks later...
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
