I have three full sets of wheels for sale.
All are located in Newcastle NSW.
Will post at buyer's expense and at this stage buyer's organisation as well. Located only 10 minutes off the pacific highway so not too tough to get to from Sydney.
1) SSR Formula Mesh, 4x114.3 15x8.5 +4, 15x9 -2. I refurbished these wheels, all new nuts and bolts, polished lips, 2 pak painted centres. All centre caps, new centre cap stickers, new chrome valve stems. Tyres are 205/60R15 Dunlop Direzza ZR1 Starspec and 205/55R15 Dunlop Direzza DZ1. $2200
Mounted on my Silvia.
2) PIAA single piece, 5x114.3, 17x9 all round (all four). Originally ment for a GTR, these have just been resprayed in 2 pak silver. Tyres are worn out (rear) and have camber wear (front). Very minor gutter rash on two of them. $1100
On my Silvia a few years ago before they were resprayed.
3) SSR Vienna 17x8/17x9 4/5 stud multis on a 114.3 PCD. 32 offset all round from memory, near new tyres. Front Blue Streak Stilleto 225/45, rear Blue Streak Stilleto 235/45. $1300.
Two of these wheels mounted on the back of my 180sx back when I lived in Japan.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
