Hey guys, my water pump split the other day and drained most of the coolant, i noticed quite quickly that there was a problem, but with a very tight inlet cam and some other tests done, its confirmed, my head is warped >_<
What i'm looking at is using a engine crane to lift the body over the engine( no i don't have a hoist), leave the motor and box together mounted on the subframe, replace the head, reasemble and refit.
I'd like to know if you guy recon its the best way to tackle the situation.
only thing i was thinking is lifting the car that high, would the rear bumper hit the ground....maybe??
any help from people that have removed the engine out the bottom without a hoist would be appreciated also.
you might not get it high enough to clear the engine and that, easiest way is just to pull the engine and gearbox out as one that way you can still push the car around and steer it easy without having to fight an engine crane aswell
You could try and put the car up on ramps with the back wheels and stands at the front. Wheel a trolly under the engine and gearbox and lift the trolly up to the engine and gearbox, then lower it down to the floor. Then use your crane to lift the front of the car up high enough so you can roll the trolly out. The ramps under the rear wheels will ensure you dont scrape the back end of the car on the ground. Using a block and tackle to the roof to lift the car is another approach ive seen.
Its a lot of hard work if you havent done it before, so its a good idea to get someone involved thats has done it to make sure you dont un-necessarily remove things that dont need to be removed. You'd be surprised just how complete the whole assembly does come out.
You could take the head off with the engine still in the car..
But you have an engine crane obviously.. why try lift the car up? just take the bonnet off and pull the engine out the normal way.
I have thought about it both ways, done some searches on SAU too, i was originally thinking i would remove the head in the car, but after some reading it seemed some people thought it was easier to just remove the whole engine.......
Initially i was going to remove all head bolts and pipes etc and try are remove the head with the turbos and plenum intact, obviously using an engine crane or block and tackle, reassemble all gear to the new head, with jun cams,:thumbsup: and refit.
I have removed this motor before and plenty of others amongst buiding a few rb30's, so i'm no stranger to the whole engine thing, just the 32 GTR engine / engine bay is kinda tight, just trying to see thoughts on the easiest way.
Dropping the whole subframe from a GTR is the hard way of doing the engine.
Leave the box in and only pull the engine.
Heads in situ are not not hard.
Leave the turbos in place and undo the two four bolt flanges, manifolds stay bolted to the head
Strip the front and remove timing belt etc obviously.
Remove alternator and starter motor so you can get the intake side off easier.
With the intake side off the rest is simple.
I don't ever recall pulling an engine to do a head, I know it's common practice but unnessisary.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
