i currently have an issue where the car leans out with anything over 8psi boost.
Mods are:
3 inch exhaust
Front Mount Intercooler
Apexi pod
Blitz Dual stage boost controller
Walbro Fuel Pump
All plugs, fuel filter are new and AFM is clean. There is no vacuum leaks.
I had it on the dyno today to check fuel mixtures and everytime we start adding boost it leans right out.
We cramped the return line hoping it something stupid like a fuel reg issue but that didnt make any change.
Power output at 8psi is 167kw at rears tyres
How much boost and power are ppl getting and does anyone have any thoughts on whats causing it to lean out like this?
https://www.sau.com.au/forums/topic/354817-problems-making-power/
how did you wire up walbro? when i put one of these on my car we had same problem and found fuel pressure was dropping when coming on boost, i ran a 10g wire from back of alternator through 20amp fuse and to a 20amp relay switched on by factory fuel power feed and no more fuel issues
The fuel pump i used is that same in my racecar which has 270kw at rears with no fueling issue.
Though i might try hard wiring with a decent gauage cable to see if it helps.
I will have access to the dyno again tomorrow so the more ideas i have to try and fix it the better
Injectors should do more than 200kw at least. Maybe your race car has battery in the boot? Walbro flow drops right off when boost increases and needs all 14v to function properly. Replaced the filter in the engine bay? Time for a Nistune chip!
rather than jumping straight into rewiring the pump, try putting a multimeter across the terminals and see if you're getting a voltage drop - but i'd say upgrading the wiring and running it off a relay is a good safety measure anyway.
and if you want to do some forward planning, use Amp wiring OAWG or similar - run it to your boot and into a distribution block - then run some thicker wiring like 8AWG off that for your pump (dont' forget to fuse it).. bit of overkill, but then if you want to add amps later, you're set!
Edited by SMOKEYC34
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
