Hi there,
My 34 Getrag is really hot when running for long period of time. After a cruise last Sat night on the hills the knob get so hot that I need to keep fingers away from the metal part otherwise it will get burnt. Outside temp is sub 15C.
Later on a friend drove my car and first thing he noticed is the hot gearbox. I had a 34Gtt and the never noticed any heating issues with the 5-speed-manual.
Is it normal for a getrag to be so overheated compared to other gearboxes? What's the ideal street/track temperature for a getrag?
Thanks.
Andrew
https://www.sau.com.au/forums/topic/354820-getrag-overheat/
Sorry no idea about the heat, but you may as well make sure its got the correct fluid as the most basic maintenance. Oddly, the getrags actually require synthetic auto transmission fluid, like castrol transmax Z. IIRC redline superlight shockproof is an alternative. You could open the fill hole and put your finger in to see if its the usual transmission fluid red, but if you havent changed the transmission fluid since you got the car you might as well do it for peace of mind.
https://www.sau.com.au/forums/topic/354820-getrag-overheat/#findComment-5682754
Thanks very much Adam. Changed the gear box oil with Castrol Transmax Z however it's green instead of red. Gear change feels so much more smooth now and I doubt workshop which rebuilt my gearbox has put regular 75-90w gearing oil in it before. Because Transmax Z is a really light oil, is it sufficient to protect the gearbox?
The mechanic mentioned that the front bearing is a bit worn out and making noises. Is it a serious issue? Currently running Excedy twin plate clutch.
https://www.sau.com.au/forums/topic/354820-getrag-overheat/#findComment-5684050
if you have a worn gearbox bearing that will be generating heat (due to friction). there is also an insulator between the shifter mount thing and the box. sometimes they get left out. if that's missing you definitely will get more heat transfer into the shifter and gearknob. can't remember in 34 GTR but in 32 GTR the shifter actually goes into the transfer case anyway and not the gearbox.
https://www.sau.com.au/forums/topic/354820-getrag-overheat/#findComment-5685706
Thank you Richard. Will look into it.
https://www.sau.com.au/forums/topic/354820-getrag-overheat/#findComment-5686524
Is the temperature any different with the new fluid?
Did you say transmax Z is now green (or was green the colour of the old fluid)? It was red when i used it in my powersteer about 18 months ago.
If you're running 350+kw it might be worth using superlight shockproof instead. I have no direct experience tho, just what's bounced around my skull after lots of reading. BeerBaron or TO4GTR etc would know.
https://www.sau.com.au/forums/topic/354820-getrag-overheat/#findComment-5686649
Did another hill run last night. Temp is definitely lower after oil change. Syncho is much more smooth. Thin oil helps.
Yes the Transmax Z is green. The old oil is regular yellowish color.
With 286awkw it's a mild gtr.
Thank you very much Adam.
https://www.sau.com.au/forums/topic/354820-getrag-overheat/#findComment-5686780
You cannot use the redline in the Getrag IIRC...
Pretty sure it has been mentioned here that superlight (ONLY superlight) is recommended by Redline for that box. I found it hard to believe at the time, but IIRC the poster had called Redline. Would definitly be worth confirming with them before trying it.
Anyway Andrew at that power, stick with the transmax Z.
https://www.sau.com.au/forums/topic/354820-getrag-overheat/#findComment-5687500
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
