Can someone please explain to me why and how the "Friends" stuff works???.
Some user that I have no idea who he is has added me as his friend.
Now me being my usual rude grumpy old bastard self would just delete him and tell him to f**k off but I'm mellowing in my old age and thought I would ask the question first.
Cheers
Neil.
https://www.sau.com.au/forums/topic/354825-friends/
+1, and how do you remove them? I can "manage" my friends... but not remove people who add me randomly. Probably the same person as Neil.
Probably the same guy who has been adding everyone else. To remove them click on their name and it takes you to their profile. Then their should be on the page remove me as friend
https://www.sau.com.au/forums/topic/354825-friends/#findComment-5682758
You can not control who adds you on their friends list. You can only control your own friends list. It isn't a two-way thing.
In your "Profile" tab
Go to where it says "Show my friends in my profile"
under that is "Friend Approval".... you can choose "Disabled - Allow addition without approving" OR "Enabled - Only add when I approve them"
https://www.sau.com.au/forums/topic/354825-friends/#findComment-5682778
lol sif you have friends!
Could YOU please be a little more constructive with your comments.
Post whoreing my thread is not required!!!.
I can push the report button you oxygen-thief.
Now back on topic,,,is there any advantage to having "Friends",,,?. I think I've worked out how to remove a friend,,,but I'm at a loss to work out how to add friends.
Cheers
Neil.
https://www.sau.com.au/forums/topic/354825-friends/#findComment-5682790
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
