1990 R32 GTS-t Type-M - Thousands Spent.
Resprayed in GTR Yellow with black engine bay. Car was previously Maroon. 254,000km on chassis, which is fully optioned from factory including
- Electric Sunroof
- Speed sensitive steering
- Rear Spoiler
- Digital Climate Control (A/C removed)
- Resprayed GTR Yellow
- Resprayed engine bay gloss black
Engine Bottom End (All components except crank block and rods new at 253,000km, assembled by Donny @ Streetforced)
- Forged and Stroked Rb22det
- Bored, Honed, clearanced and decked
- Custom 80mm CP pistons
- Rb26 crank
- H-Beam rb26 rods
- ARP2000 rod bolts
- ARP head stud kit
- Greddy metal head gasket
- Cometic steet pro full gasket kit
- Nissan N1 water pump
- Nissan thermostat
- Nissan N1 oil pump
- Nissan belt idler
- Nissan belt tensioner
- Nissan timing belt
- King bearing kit
- Balanced and blueprinted.
Engine Top End
- Machined Head
- Tomei Type A valve springs
- KLS cam gears
- Valve grind and reseat.
- K-Lined Guides
- New Valve Stem Seals
ATOM 2.2L RB... Starting price shown here, this engine has more $$ in extras than shown here
Turbo Setup
- Fresh RB25 turbo (minimal axial shaft play, no wheel damage) (Installed at 253,000km)
- Midnightmods braided turbo lines (new at 253,000km)
- Turbotech boost controller (new at 253,000km)
- Conelock nuts used on all exhaust parts (new at 253,000km)
- All exhaust gaskets cometic multilayer stainless steel (new at 253,000km)
Engine Support Accessories
- All coolant lines replaced and simplified (new at 253,000km)
- All vacuum lines replaced and simplified (new at 253,000km)
- All belts replaced (new at 253,000km)
- Splitfire coilpacks
- Walbro fuel pump (new at 253,000km)
- Fuel pump wiring upgraded (new at 253,000km)
- 3" split dump/front pipe, heat wrapped, flexi section take pressure off turbo, no cat
- 3" Xforce exhaust system, one full muffler + cannon
- Nistune Ecu, tuned by Nick Summers (new at 253,000km)
- Z32 Air Flow Meter
- 440cc GTR injectors
- Racetech 52mm Electric Smoked Face Stepper Drive Gauges (Boost BAR, Water Temp CELCIUS, Oil Pressure BAR)
- Front Mount Intercooler Kit, 600x300x76 with 2.5" aluminium piping (new at 253,000km)
- Stainless Steel Intake (new at 253,000km)
- Apexi Pod Filter (new at 253,000km)
- ASI 52mm Twin Core Aluminium Radiator (new at 253,000km)
- New engine mounts (new at 253,000km)
- Non-Hicas Power Steering Pump and Resivoir (installed at 253,000km)
- Power Steering Cooler (installed at 253,000km)
Gearbox
- Excellent condition RB20 gearbox
- Extreme Heavy Duty Organic Clutch (new at 253,000km)
- Nulon Gearbox Oil (new at 253,000km)
- Output shaft seal (new at 253,000km)
Suspension
- Nismo Adjustable Struts and Springs
- Superpro Steering Rack Bushes (new at 253,000km)
- Nolathane Sway bar end link bushes (new at 253,000km)
- Solid Steering Column Spacer
- Hicas lockout bar (every line, bracket, pump etc removed) (new at 253,000km)
- Tuneagent Subframe Locking Collar Kit (new at 253,000km)
- 18x8.5" chrome wheels (polished at 253,000km)
- 235/40/18 tyres all round
- Rolled Front gaurds
- R33 rear brake upgrade
Audio/Visual
- Touch Screen DVD Player Headunit with GPS, Bluetooth, Ipod Control etc
- Front Jaycar Kevlar 6.5" Splits
- Rear Jaycar Venom 85WRMS 6.5" Splits
- Jaycar 4x50WRMS Amplifier
- All brand new wiring, including premium RCA cables and 28 strand speaker flex
- Battery Relocation to the boot
$14,000
Phone/Text Dave 0409 631 092
As always im sure there is some things I have upgraded or replaced that i have forgotten about. This car is like a completely different car to drive now that ive spent the money where needed.
https://www.sau.com.au/forums/topic/354862-fs-yellow-r32-skyline/
