Hi all. I have been planning this swap for quite a while (after vicroads and EPA squashed my RB30DET in R32 plan).
What i have worked out so far is:
Buy R32 GTR front cut
Take engine, harness and computer.
few small engine mods (oil drain at rear of head, high volume/baffled sump)
get an RB25DET g'box and clutch etc (do navara speedo swap)
bolt it into the GTS-T.
What issues am i going to have as far as interchanging parts.
What should i do with the front diff on the GTR sump (can you get a plate to block the sump up if you take it out?)
Do GTR intercooler kits/piping fit a GTS-T (or is there a difference in the front of the cars?)
Will original gtr airbox fit in the gts-t engine bay?
will a catchcan designed for an gtr engine bay fit the gts-t engine bay? (one from hiOctane.com)
Will an X-Force GTR exhaust fit the gts-t undercarriage?
Anything else you can think of?
Ta
https://www.sau.com.au/forums/topic/354880-rb26dett-into-r32-gts-t/
oil drain and bigger sump are the least of you worries, the 15-20yo 32 motor is... IMO don't chase more than 280rwkw.
sump, just get the diff removed and welded up hole, works fine.
airbox should be fine
BOV setup might need custom work to fit
I'll address the intercooler issue.. you can bolt up a whole 32R intercooler/piping/bov setup including the plumback pretty easily, I only had to drill one hole for a vacuum hose. Have to make sure you get EVERYTHING though(all brackets, bulkhead fittings, rubber pipes etc), have a search for a 32GTR workshop manual, there is an exploded diagram of the intercooler and turbo piping setup which helped me a lot when installing.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
