Car is in excellent condition. Very low Km's. I imported the car from Japan myself in 2008. Engine FULLY rebuilt only 20,000kms ago with forged internals. Had big plans for it but unfortunately i have to move for my career and the car cannot come with me due to living arrangements. Engine runs very smoothly, haven't had a single problem since rebuild in '09. Car has been extremely well looked after and loved. Oil and filter always changed before every 10,000kms. Tasteful modifications, car is very clean and tidy. Excellent example of an R33. Includes very rare factory electric sunroof. Car has huge potential for high power with a bigger turbo, up to 300rwkw reliably, or leave it as is, as an extremely reliable everyday car. I have only ever run on the stock 7psi boost since rebuild, car has been babied and not thrashed. Over $20 000 spent on car since purchase, I have most receipts including rebuild receipt. Very regretful sale. Call for inspection. Genuine Buyers Only
14,999 Ono
Located in Hobart, TAS
Contact Matt on 0400 129 189
ENGINE REBUILD INCLUDES:
-Forged ACL Pistons-
-ACL Piston Rings-
-ACL Main and Head Studs-
-ARP Rod Bolts-
-Performance Timing Belt-
-Performance Oil Pump-
-Bored Oil Return Line-
-New Timing Belt Tensioner & Idler-
-New Welsh Plugs-
-New gaskets including Cometic head gasket-
-Flywheel Machined-
-New Thermostat-
-Block Bored and Honed-
-Machined Crank-
-Valves Reground-
-New Gearbox Oil-
OTHER ENGINE MODS:
-Saber Intercooler-
-Extra Heavy Duty Clutch-
-Cat Back Exhaust-
-Magnaflow Duel Tip Muffler-
-APEXi AVC-R Boost Controller-
-Pod Filter-
-Metal Intake Pipe-
SUSPENSION WHEELS AND BRAKES:
-Tein Coilover Suspension- Adjustable Height and Damper-
-Keiichi Tsuchiya Wheels- 17 x 9 Rears and 17 x 8 Fronts-
-Mintex Brake Pads-
-HICAS Lockout bar-
INTERIOR:
-Carbon Fibre Dash-
-Nismo 300km/h Guages - Car has no speed limiter-
-Saber Boost Guage-
-Momo Gotham Steering Wheel - With Quick Release-
-Momo Gotham Gear Knob-
-Turbo Timer-
-Pioneer Head Unit- 6 Stacker in the boot-
-Pioneer TV Screen - Wired into iPod connector-
-Pioneer Kevlar front Speakers
Edited by MAT00
https://www.sau.com.au/forums/topic/354904-1995-r33-gts-t-for-sale/
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
