Dont know how but the shaft out of the W/P to the fan, sheared off. F#*+KD the fan, the shroud and the radiator.I have a radiator and shroud but will also need a fan.Am putting the fan in the WTB, but where to get a W/P quickly.
https://www.sau.com.au/forums/topic/354915-water-pump/
hey hugh just get a vl commodore pump from super cheap or globe $50-$80 1 bolt hole needs to be plugged and away you go.
https://www.sau.com.au/forums/topic/354915-water-pump/#findComment-5684738
Well, I got a VL water pump from Globe today. $90, and Repco etc all wanted $90.
The bit about plugging a hole is interesting. I am sure that the shagged pump was a VL caus it had a hole in the casting that was plugged in the block.
Am slowly getting the 25G back together. Not too sure about the tension pulley for the T/B.
If anyone out there has done this would appreciate some info. Either a PM or a phone No and I will call .
https://www.sau.com.au/forums/topic/354915-water-pump/#findComment-5688291
